Every other column of red pixels won't display on Sony KDL-52XBR9 LCD
This topic has been answered.
  • SurrealMustard
    • Jan 2015
    • 487
    • The United States of America
    It's been a while since I've run into this before, so I could use a little help. The attached image is a close-up of a solid white screen. What I'm seeing is red-green-blue-black-red-green-blue instead of red-green-bue-red-green-blue.
    I haven't cracked into the thing yet, but before I do, has anyone encountered anything like this before? If so, what was the solution? T-Con? Ribbon connections? Something else?
  • Answer selected by SurrealMustard at 03-10-2025, 06:37 PM.
    SurrealMustard
    • Jan 2015
    • 487
    I'm pleased to report that the repair (if we can call it that) was a success! The connection between the mainboard and t-con was loose on the mainboard side. One of the clips wasn't quite in all the way. Carefully reseating the connection was all it took, and the image cleared up immediately. PQ is fantastic now, (although the input lag is as dreadful as it ever was, but that's just the nature of this set) so I'm happy with that. Another victory for the repair team 👌.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4546
      • Italy - Milan
      Guy, i.see something different!... i see RED, YELLOW, BLACK, GREEN... is it maybe a screen from Sharp? Maybe quattron technology.. it misses blue.. it can be a flat cable from tcon to panel or a missing EOL resistor on the screen stripe board or tcon.. i don' t know..
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        Looks normal to me, looks like red-green-blue-green repeated which is fairly common?
        If there is no blue the screen would be yellowish. If it's white it's fine...
        actually i'm not sure what i'm seeing, pixels are not perfectly focused. hmm
        • Diah
          • Feb 2013
          • 6614
          the close up Picture are normal for set seam it had 10 bit or more picture processing Panel .. thought 10 bit and higher can produce over billions color.
          • SurrealMustard
            • Jan 2015
            • 487
            Pretty sure it's not an RGBW. I am kind of curious now to get the back cover off and see who makes the panel.
            Is red-green-blue-green a common layout in LCDs this size? I just can't imagine that it's supposed to look this way. It's one thing to have shared subpixels on a 2k/3k tiny phone screen, but when we're talking about a 52" 1080p panel, it's a significant deficit.​
            Last edited by SurrealMustard; 02-01-2025, 08:06 PM. Reason: Adding additional quote
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4546
              • Italy - Milan
              How does it look this white image? White? Yellow?
              • SurrealMustard
                • Jan 2015
                • 487
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4546
                  • Italy - Milan
                  i am curious how it looks on a close up photo of pixels now
                  • SurrealMustard
                    • Jan 2015
                    • 487
                    Fixed 52XBR9
                    Nothing too earth-shattering. Red green blue, red green blue.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4546
                      • Italy - Milan
                      it seems RYGB, the pixel is clearly sqare
                      • Daren87
                        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                        by Daren87
                        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                        08-13-2023, 03:25 PM
                      • iglitare
                        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                        by iglitare
                        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                        Backlight seems to work, Sound (Setup menu after reset) works.
                        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                        With my small knowledge i would think at least the cables are good.
                        Can this happen because of a bad tcon board?
                        Or is it always a bad/shorted...
                        09-04-2025, 07:13 AM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • rimwall
                        Sony KD-65x7500D - double image - Tcon or Panel?
                        by rimwall
                        This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                        I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                        11-18-2025, 02:09 AM
                      • thelankanguy
                        Sony KD-55X9000F TCON Issue
                        by thelankanguy
                        The TV shows a black screen with no image.
                        TCON ribbon connectors were disconnected individually for image and there was no half image even.
                        Later both ribbons were disconnected and TCON voltages were tested.
                        12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                        There is also a short to ground in this circled inductor.
                        Is this a TCON issue or something else ?...
                        12-13-2024, 12:27 AM
