Vizio 65" Model M3D650SV standby only
  • getto
    • Jul 2012
    • 17
    • usa
    Standby light only won't turn on from either tv or remote. No visual signs of leaking caps.
    Before tv went dead I did have a fine line running from top to bottom, about 4 or 5" from right side of tv. One Black line at first then months later it became two and three, other lines were different colors. The lines would stay on for about 10 minutes and faded away. Was thinking a dirty ribbon cable until this happened. Tv can't be more than 5 years old at best.
    They just don't make stuff like they used to. Second flat screen that went down. Thanks to all the people on this site that make it possible to ease the pain.
  • getto
    • Jul 2012
    • 17
    • usa
    Re: Vizio 65" Model M3D650SV standby only
    I forgot to mention when I plug it in to ac outlet the standby light glows bright orange and fades to a lighter shade.
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
    • brad2157
      Vizio E70-E3 Two white vertical lines
      by brad2157
      I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
      Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
      Replacement main board - Boots up fine, but starting...
      12-13-2021, 05:11 PM
    • x_orange90_x
      Vizio V585-J01 dancing lines and image doubling
      by x_orange90_x
      I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
      Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
      Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
      I swapped...
      06-12-2024, 07:57 AM
    • viking509
      vizio e65 e3 LED tv color vertical lines center tv only
      by viking509
      I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
      03-21-2023, 12:48 AM
    • p-top
      Vizio, E60u-D3, no standby light, no ps_on
      by p-top
      Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
      main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
      PS voltages
      1 VSNS -2mV
      2-5 LED-OUT -2mV
      6-10 GND -2mV
      11 +16VS 16.29V
      12 AC-DET 3.929V
      13PS-ON -3mV
      14 +16VS 16.29V
      15 +16VS 16.29V...
      11-27-2023, 10:44 AM
