Samsung UN40EH5300 on/off
  • Jeff Hartmann
    • Jun 2014
    • usa
    I have searched, not found.
    UN40EH5300, LED TV, cycles on and off about every 5-10 minutes for the first 30-40 minutes, then stays on. Picture and sound are fine. However, the smart stuff is not working. It will not see the WiFi.
    I Googled and found a main board (allegedly reman by Samsung) and found a Power supply (allegedly from a cracked screen TV....probably cycled on and off and they kicked it )
    The main board came in first, installed, and it saw the WiFi, and then cycled off and on. The next day the power supply arrived, it did the same cycle on and off.....and now the new Main board will not see the WiFi. And, occasionally the menu functions freeze until a restart.
    Did I ruin the new main with a bad PS?
    All Caps on both boards look fine, no evidence of heat, I haven't noticed any bad solder joints.
    Temporarily we let it warm up, then use it with a RoKu for smart TV stuff.
    Samsung (of course) said it was out of warranty, and a local shop quoted enough that they could bring a new TV to replace this one.
    I think the manufacture date was 2012.
    Jeff
  • Jeff Hartmann
    • Jun 2014
    • usa
    Re: Samsung UN40EH5300 on/off (repaired!)
    Since it was turning on and off, and the WiFi didn't connect, I bought a power button, and WiFi module.
    TV functions normally again.
    • jose6326
      • May 2013
      • 707
      Too bad you didnt post pictures of all the boards.
      Im guessing you put everything back together already
      • Jeff Hartmann
        • Jun 2014
        • usa
        I still have the old boards, keeping them for spares..If it helps someone I could post pics. Even though there was no change with the replacement boards I left them in. So the originals are on the shelf.
        All in it cost about 45 dollars in replacement boards. I think the only one that was bad was the On/off board and maybe the WiFi module.
        • royston
          • Mar 2015
          Jeff
          Hi Jeff,
          I have the exact model of your TV: Samsung UN40EH5300FXZA version: TH01 and the exact same problem. My TV is less than two years old and upon turning it on, it starts to power off and on periodically for the first 30 minutes or so. It also doesn't recognize my WiFi although my tablet does. I opened it up and the caps look fine although reportedly that doesn't mean they aren't bad. After considerable internet research, it seems it could be the power board or the main board. Like you, I really don't want to buy a part that doesn't solve the problem. Could you explain what/where is the WiFi module and how you replaced the power button? I don't use the power button to turn the TV on/off, I use the remote. I would appreciate any assistance. I can send you pix of my open TV and maybe you can point out what is where. I might even be interested in buying your spare boards if it comes to that. Thanks.
          • Terryfictv
            • Mar 2011
            • 124
            You should consider the on/off power/button assembly. The part number is BN96-22413Q for your Model 40". I have the same issues with a UN50EH5300FXZA.
            The part number for mine is the same but ends with M.
            I will follow up when I complete the repair....
            • Czigo
              • Apr 2015
              I have been dealing with random power off/on issues for my Samsung UN40EH5300 TV for a while now. At times it's every 2-5 mins that the TV will shut itself off and then back on, other times it'll stay on for a whole day. There's also an issue with the TV turning itself on after turning it off which can be annoying if you're trying to sleep.
              I ordered two replacement boards, BN44-00498B and BN94-05917S | BN97-06298N
              Switched them out today, but the off/on problem still persists. Perhaps the new boards I got are faulty as well.
              Any news here about successful repairs would be much appreciated.
              • tooth
                • Jul 2015
                Thank you for your post! Mine started turning on and off too. I bought just the power button, used, on eBay for $5 free shipping and now it works again.
                • Nick's Tvs
                  • Jan 2014
                  • 621
                  One quick way to make sure your button is the issue is by turning your set on, disconnecting the button and then waiting to see if it still turns itself on and off. I am not sure if the IR sensor is located on the button but if it is not, you can still use the remote to turn everything on and off and won't need to replace the button at all.
                  • tooth
                    • Jul 2015
                    Nevermind, still broken.
                    • Rob Lucky
                      • Jul 2015
                      Not sure how to post a thread but here goes my questions: I have a 32" Emerson led tv Model Number lf320em4f push power button Emerson comes on screen for a second then goes off; 46" Mitisubshi Model Number LT-46164 Green light on front of set blinks constantly; Samsung tv Model Number pn60e530a3f samsung music comes on then off no sound or picture sometimes red light under power button blinks; Samsung Model Number ln40c530f1fxza how do you remove the remote sensor board. Thank you for anyones help.
                      • tooth
                        • Jul 2015
                        I switched out the main board. That didn't work. While in there, I noticed the wi-fi module was very hot after the TV had only been turned on for 2-3 minutes. I removed it. So far the TV isn't turning on/off any more. Perhaps it's been overheating and causing the tv to turn off as a safety mechanism?
                        • tooth
                          • Jul 2015
                          It's been a few weeks now, and the tv no longer turns on/off by itself anymore. It appears the wi-fi module was overheating. Since I have have the tv connected to my PS3 which connects to the router wirelessly, I don't need the tv's wi-fi module. Just taking it out solved my problem. I don't think it's worth buying a new wi-fi module as they appear to break so easily.
                          • Jan250
                            • Oct 2015
                            • U.s.a
                            Re: Samsung UN40EH5300 wifi stopped working
                            Hi
                            My wifi stopped working on this brand. Everything else works fine. Where can i puchase a wifi module board and what is the model # for the wifi module board for this tv UN40EH5300.
                              Check SHOPJIMMY.COM
                              • neilc6
                                • Nov 2015
                                • 1550
                                Got this model in with the problem of the TV resetting after several minutes. Going into the network setting freezes the firmware. Swapped the WIDT20R wifi module with one I had and it seems to have resolved the resetting. However, the wifi can't find any networks. My parent's UN46ES6100F has the same problem. Tried changing the Wifi Region to A in the service menu and doing a service menu reset and with no success. These modules are pretty expensive on ebay (around $50 USD) and Chinese knockoffs on Aliexpress are under $20.
                                • neilc6
                                  • Nov 2015
                                  • 1550
                                  Got two WIDT20R modules for $15 USD each on Aliexpress and wifi on both TVs are now working.
                                    09-07-2024, 05:50 AM
                                  • Asraf Atb
                                    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                    by Asraf Atb
                                    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                    01-27-2025, 05:02 PM
                                  • JSin21
                                    Compatibility of main boards between different variations of samsung MU6100
                                    by JSin21
                                    Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                    I have Samsung Smart TV UA65MU6100WXXY version DA01
                                    Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                    11-27-2023, 04:54 AM
                                  • mrautom8
                                    Samsung TV UN75H6350AFXZC main board schematics?
                                    by mrautom8
                                    Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                    Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                    While relay is on, all voltage rails are present and steady (scoped) on main board.
                                    I love a good logic puzzle but getting lost without any schematics.
                                    No shorts on ANY capacitor main board.
                                    Thermal camera shows 3.3V inductor getting warm instantly but...
                                    10-19-2025, 06:32 PM
                                  • Yanleb
                                    Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                    by Yanleb
                                    Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                    If they are not compatible why did Samsung give them the same part number to begin with?
                                    08-04-2025, 11:35 PM
