VIZIO VA26LHDTV10T has white vizio logo before pressing power on. no backlight.
  • triplefour
    • May 2014
    • 1747
    i picked up this VIZIO VA26LHDTV10T today from the recycling center for 10$ as soon as i plug it in, the vizio logo turns white. i think its supposed to be amber first, in standby until i press power but it just turns on as white, i never see the amber. pressing the power button does nothing. it doesnt turn it off or on. its just "on" immediately as soon as i plug in the power.
    the backlight does not come on, its just a blank unlit screen.
    i took it apart and tested some voltages which i will post.
    i dont see any bad caps or any fried components.
    i thought that ceramic capacitors are non polarized, so why am i getting a zero voltage reading on one side like its a ground? or is that a sign that the capacitor has failed?
    i took all these measurements with the negative lead of the main filter cap as the ground. except the connector measurements which i used chassis screw as ground.
    i can see clearly im not getting the right voltages to the mainboard. if the white light is on it should mean the 12v power is flowing but it isnt..im only getting .09
    so what may be going on here?
    Don't fear the repair...
  • triplefour
    • May 2014
    • 1747
    Re: VIZIO VA26LHDTV10T has white vizio logo before pressing power on. no backlight.
    the "primary" and "secondary" markings on this board are pretty ambiguous...
    • triplefour
      • May 2014
      • 1747
      getting some weird measurements on IC902 which is labeled A6069H SK981
      for one thing the 6th pin seems to be missing.
      and pins 7 and 8 make my voltmeter make some crazy feedback noise and the current alternates between 12v and 1 and then eventually just stays at 1.. or something like that. its weird.
      could it be this chip is bad?
      • philliesfan30m
        • Aug 2013
        • 542
        vizio's are known for having bad voltage regulators on the mainboard. i would check u150-u154 and see what voltage readings you are getting my guess is probably 1 of them is bad. some might be fixed or adjustable. you will have to check the numbers on the regulators to find out what they are. i can't tell from the pics. i don't think that chip is bad or you probably wouldn't have any standby voltage.
        • triplefour
          • May 2014
          • 1747
          ok yeah that logic makes sense.
          its seeming more like a mainboard issue.
          i guess i could jump the power board to really test that...
          so on the voltage regulators all look fine to me but maybe im wrong so heres the measurements i got:
          u150
          L302
          1: 0
          2: 3.3
          3: 5
          U151
          L1117-33
          1: 0
          2: 3.3
          3: 5
          U152
          L302
          1: 0
          2: 3.3
          3: 5
          U153
          L1117
          1: 1.25
          2: 2.5
          3: 4.2
          U154
          L1117
          1: 0
          2: 1.25
          3: 2.5
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            Did you already check the capacitor's with a meter?
            • Ltank
              • Jun 2013
              • 776
              Is 498 resistor open looks like a burn spot next to jumper. These very low ohm resistors are wire wound either show short when good or open when bad. Its a 47 mili-ohm value 2 Watt
              Resistor
                This section is the standby power supply, it is working otherwise you will not have WHITE VIZIO LOGO. I hope you did not damage the meter, that pin 7-8 are the Drain pin which will have high voltage spike on them.
                  BTW, right now PS_ON is less than a Volt but enough to turn on the PFC Voltage booster to give you 370VDC on the two legs of the MAIN filter cap, no ON/OFF signal to turn on the backlights, no 12V, 24V either. I hope that voltage readings you are showing in the primary side are done using the correct Ground ref point. What did you use for Ground ref point?
                    You can see thick black line for the separation between Primary and the Secondary.
                      Power supply board block diagram.
                      • triplefour
                        • May 2014
                        • 1747
                        yes i used the negative leg of the main filter cap as the ground reference for all those measurements except the ones on the connectors. i used the chassis screw for those. thanks for the block diagram, that is very educational.
                        i dont think i damaged my meter...it still reads everything else correctly....
                        my meter can measure up to 600v so it would have to be really high voltage to break that, right? sure dont want to break my meter!
                        i havent checked any of the capacitors, because i would need to desolder them to do so, (and they all look fine) and id rather poke around a bit more before i just start guessing... is there some way i can test a capacitor (even a really crude test just to see if its totally broken) before taking it out? ill check resistor 498 for open and post back in a minute.
                        • triplefour
                          • May 2014
                          • 1747
                          ok resister R498 read at .8 ohms so thats not it...
                          • triplefour
                            • May 2014
                            • 1747
                            guess i may as well test all the other resistors for open...
                            • triplefour
                              • May 2014
                              • 1747
                              wait it was R948 not R498... either way i tested all resistors and diodes i could see and none of them were open. all had some resistance.
                              • triplefour
                                • May 2014
                                • 1747
                                i noticed that diode D935 allows current to pass in both directions. that cant be right, can it?
                                  As I indicated in post 8, again, that section of the standby power supply is working otherwise you will not get the white VIZIO Logo. You have problem with the 12V24v POWER SUPPLY SECTION, not in the section as shown in post 3.
                                  • triplefour
                                    • May 2014
                                    • 1747
                                    ok but a diode that can pass current both ways is defying the normal concept of what a diode is, isnt it?
                                    • triplefour
                                      • May 2014
                                      • 1747
                                      i guess it doesnt matter since as you say thats in the 5v standby section and i do have that. what im wondering then is why the logo is white, when it should be amber. also what can i test in the 12v24v section?
                                      • triplefour
                                        • May 2014
                                        • 1747
                                        i really would like to know an explanation for how a diode can pass both ways though...kinda messing with me
                                        • Daveleone
                                          Vizio VO42L, white logo, no backlight, no picture
                                          by Daveleone
                                          Hi all! I've got a Vizio VO42L. Plug it in, and logo flashes orange/white for a bit, then solid orange. Press power, and logo changes to white. There is no backlight.
                                          From reading some of the posts here I thought the inverter could have been the problem, but I've replaced it and still have the same issue. I noted that shining a flashlight on the screen shows nothing, so now I'm thinking main board?
                                          I took the following readings with the TV powered on. I also tried taking the readings with the CFL connectors unplugged - no change.
                                          Main board:
                                          Continuity across...
                                          02-20-2021, 04:52 PM
                                        • Super360
                                          Vizio E701i-A3 Vizio logo flashing then turns off
                                          by Super360
                                          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                          07-25-2024, 07:06 PM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                          MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 07:46 AM
                                          MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-06-2024, 07:29 AM
