  • TR103
    • Jan 2025
    • 3
    • Netherlands
    - it keeps rebooting
    - without cable between mainboard and lcd panel and with a jumpered mainboard, it does not reboot and I do have 25V VGH. With the cable connected the VGH drops to 0V. But with the lcd panel connected, it keeps rebooting, even without the ribbon cable (without the jumper it does boot without the ribbon cable)
    Does anyone have any ideas? Is there something else I can test? I know this tv is known for its bad panels, but when I tape off all the clock-signals, it still reboots with no picture. I would like to know what is wrong with it, and why only taping off pin1 (the innermost pin) is the only pin that keeps it from rebooting. The signal on pin1 could be FB_2 (I found this somewhere else on this forum). But what is FB_2? I am ok with writing this tv off, but I would like to learn more, what exactly is the problem?​
  • EazyBone
    • Jun 2023
    • 1336
    • United states
    Screen dies. These 50 inchers are crap.
    • handsworth
      • Oct 2015
      • 174
      Try this tape off. It got me a picture on a 50TU
      • TR103
        • Jan 2025
        • 3
        • Netherlands
        Thanks handsworth! I haven't tried specific that combination, but one of my tries covered more and even then it won't boot. Here are some photos what I tried already. I also tried covering just pin1 (=innermost pin, not on photos), and that is the only way to get it booting, but no picture.
        • EazyBone
          • Jun 2023
          • 1336
          • United states
          Sometimes tape doesn't work and really can't do anything about it. Could be damaged to screen you haven't seen
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • jchang
            Samsung UN70NU6900F no picture and no sound
            by jchang
            Hi all
            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
            Symptom:
            No picture no sound.
            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
            No sound at all.
            What I tried:
            1. I tried unplugging the left or right ribbon...
            01-09-2023, 06:28 PM
          • marekk
            Samsung QE55Q67RAT no sound and bad picture when streaming
            by marekk
            I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
            I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
            Mainboard is based on pcb BN41-02695A BN94-14007B
            I will appreciate any help
            Many thanks
            Marek...
            05-29-2025, 02:23 AM
          • gl4709
            Samsung un55cu7000d with backlight and sound No Video / Picture
            by gl4709
            I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
            01-23-2025, 06:21 PM
