insignia NS-L47Q09-10A no sound or picture
  • jose6326
    • May 2013
    • 707
    Re: insignia NS-L47Q09-10A no sound or picture
    I can not find U702 or U705
    I looked for 10 minutes on both sides of the board and I cannot find it
    • jose6326
      • May 2013
      • 707
      hey budm I was trying to trouble shoot the problem from page 54
      but the components it tells me to test are not on the psu, main or tcon boards
      Im not sure if this service manual is for my tv
        That is why I have you look for those IC's to find out if the service manual will be close enough to use to troubleshoot your board. Without diagram it will be real hard to trace that complex board to find out what is going on.
        • jose6326
          • May 2013
          • 707
          Is there anything else I can test?
          I can take pics of each component
          • jose6326
            • May 2013
            • 707
            I looked at the main board that is pictured in the service manual you provided and it looks exactly the same as mine
            I will look again maybe I missed something
            • jose6326
              • May 2013
              • 707
              you think I should take a chance and just buy the main board?
                Yes, just make sure it matches your original board and verify that it can be returned if it is not the right one.
                • jose6326
                  • May 2013
                  • 707
                  Budm I was looking at page 60 in the service manual you provided
                  I matched every component to the my board and to the board on page 60 and it is exactly the same
                  The only difference is the part number
                  My board is 715G3269-1
                  The board on page 60 is 715G3269-G
                  Like I said before every component is the same and labeled the same as well
                  Also when I went on ebay searching for my board the same exact board comes up and the model number of the insignia tv from the service manual comes up
                  So im guessing this board is the same for my tv and these other 2 models
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5095
                    • New Zealand
                    #29
                    Same board but different version\revision. You have -1 revision, manual shows -G revision.
                    There will be a difference somewhere, which may or may not matter.
                    -David VanHorn
                    • jose6326
                      • May 2013
                      • 707
                      but I didn't see any difference
                      I spent 45minutes to an hour matching every component on my board to the one in the service manual
                      everything is the same
                      now I just need help testing it before I buy another on from ebay
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5095
                        • New Zealand
                        #31
                        Might even be just a minor board layout change or some other subtle thing. Likely it won't make a difference.
                        -David VanHorn
                        • jose6326
                          • May 2013
                          • 707
                          so any suggestions on what else to test?
                          • jose6326
                            • May 2013
                            • 707
                            https://www.badcaps.net/forum/showth...light=insignia
                            just posting this here so I don't have to search for it
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5095
                              • New Zealand
                              #34
                              You need to find out why U702 and U703 aren't getting any power. Can you trace their input pins back to another component that might be locatable on the schematic?
                              -David VanHorn
                              • jose6326
                                • May 2013
                                • 707
                                Originally posted by budm
                                "#1 L222
                                Pin 1- 0.000
                                Pin 2 - 0.921
                                Pin 3- 0.978
                                #2 1084
                                Pin 1- 0.000
                                Pin 2- 0.093
                                Pin 3- 0.396"
                                Those two regulators (if they are regultor ICs) are not getting enough input voltage to operate, without the diagram to find out where the voltage source for these two regulators are from it will not be easy. Can we get the full numbers as printed on the bodies?
                                #1 is U703
                                #2 is U702
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5095
                                  • New Zealand
                                  #36
                                  Yes, they are getting some power but not enough. A standard linear regulator can't supply more voltage than what comes in. Only less.
                                  I've attached datasheets for U703 and U702. Check to make sure you measure the right pins too.
                                  -David VanHorn
                                  • jose6326
                                    • May 2013
                                    • 707
                                    I checked the correct pins
                                    Pin 1 is ground
                                    Pin 2 is v-out
                                    Pin 3 is v-in
                                    I get the same readings as above
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5095
                                      • New Zealand
                                      #38
                                      You will need to trace back their inputs and find where their supply comes from.
                                      Going by the photos, U703 gets its input from the output of U706 via L705. If that is the case, what is the status of U706? Does it have power?
                                      I have attached its datasheet too.
                                      EDIT: Sorry, I confused myself. According to the schematic and block diagram, U702 is powered from the output of U706. U703 is powered from the same rail (+5vSB) that also powers U706.
                                      If U703 has no power, then U706 won't either, which is why U702 isn't getting any.
                                      Looks like you need to find out why that +5vSB rail is low. Maybe there is a short somewhere? You say you get +5v from the PSU. Is that with the mainboard connected or not? Do you also get +5v at the mainboard?
                                      -David VanHorn
                                      • jose6326
                                        • May 2013
                                        • 707
                                        Yes I get +5v with the main board connectedi tested the connector on the main board coming from the psu and I am getting+5v
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 5095
                                          • New Zealand
                                          #40
                                          You get +5v on the mainboard connector, but does the +5v rail get to pin 1, 4 and 7 on U706?
                                          Looking at page 81, U706 gets +5v (via +5VSB) before the other regulators - the other regulators have their +5v (VCC5D) switched through Q703.
                                          You should also check that the +5VSB is getting to all the components in Q703's control circuit.
                                          -David VanHorn
                                          • jose6326
                                            Insignia Ns-l22x-10a no picture only sound
                                            by jose6326
                                            When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
                                            When i was removing the back cover i heard a rattle.
                                            Removed the metal plate and the heat sink was off (see pic)
                                            would this cause a no picture/image issue?
                                            What is used to put back the heat sink
                                            07-30-2024, 11:03 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
