insignia NS-L47Q09-10A no sound or picture
  • Agent24
    I see dead caps
    • Oct 2007
    • 5095
    • New Zealand
    #61
    Re: insignia NS-L47Q09-10A no sound or picture
    A 3.3v power adapter\wall-wart could work, or maybe even a computer PSU, preferably a cheap one that won't care too much about driving a shorted load.
    -David VanHorn
    • Agent24
      I see dead caps
      • Oct 2007
      • 5095
      • New Zealand
      #62
      Originally posted by jose6326
      I need help deciding which board to buy
      My board is 715G3269-1 (TQ9C8 ZK05201)
      The following has the same board number but different bar code number and is missing an hdmi port It was not removed it was manufactured this way
      http://www.ebay.com/itm/291165195578...torefresh=true
      The following has the same board number but different bar code number but is exactly like the board I have
      http://www.ebay.com/itm/261498450350...84.m1423.l2649
      I think either one will work
      Sorry, but I don't know. Hopefully someone else can give better advice on which board would work.
      -David VanHorn
      • jose6326
        • May 2013
        • 707
        Ok I replaced the main board and now I have the red led on
        But the tv still does not turn on
        Im guessing the main board is good since it turned the led on?
        What else should I test?
        • Agent24
          I see dead caps
          • Oct 2007
          • 5095
          • New Zealand
          #64
          I guess the power supply is bad or it is not getting the power up signal for some reason
          Could also be a problem with power button itself or remote sensor (I assume you tried both?)
          Could even be another faulty mainboard if it is 2nd hand.
          -David VanHorn
          • jose6326
            • May 2013
            • 707
            Well the main board is good
            I decided to disconnect the tcon from the main board
            I pressed the power button and the red led turned to blue and after 5 seconds the panel flashed
            So I disconnected the power cord reconnected the tcon cable to the main board
            I connected the power cord pressed the power button the tv screen turned on
            The bad news is that the panel is freaking cracked!
            I thought I properly checked it but apparently I did not.
            Luckily I spent 20 bucks on the set but I spent 50 on the main board
            So I guess im going to list the parts on ebay and craigslist
            Lesson learned
            Next time I will do a better job of inspecting the panel
            Thanks for all the help
            • jose6326
              Insignia Ns-l22x-10a no picture only sound
              by jose6326
              When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
              When i was removing the back cover i heard a rattle.
              Removed the metal plate and the heat sink was off (see pic)
              would this cause a no picture/image issue?
              What is used to put back the heat sink
              07-30-2024, 11:03 PM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
