LG 50PA4500 Clicking troubleshooting HELP please...
  • Dandog96
    • May 2016
    • 4
    Re: LG 50PA4500 Clicking troubleshooting HELP please...
    Genuine thanks for such a quick reply; you don't see that too often lol. Also, I disconnected the board like you mentioned and still experienced the cycle of clicking. I already purchased a capacitor so I won't be needing one from you. Hopefully, it will be arriving soon so I can share whether it was a solution to the problem.
    • Dandog96
      • May 2016
      • 4
      Unfortunately, replacing the C802 capacitor didn't help. Still the exact same symptoms (relay clicking roughly every 15 seconds and a brief red led flash). Any other ideas?
      • Dandog96
        • May 2016
        • 4
        Success! All credit goes to my father who I must give credit for this pretty impressive discovery. We replaced the C802 capacitor a few days ago to no avail. I was about ready to give up on this TV, but I asked my dad if there is anything else we can do with the power board. He inspects it and sees a spot of bad welding on the bottom of a transistor on the board. We clean it up as the metal on the pin had gotten dirty, and solder it as intended. Starts right up. Lets just hope it lasts :0.
        Also, thanks to everyone for any advice that led me along the way.
        Not a bad TV for the $20 I paid for it...
        • JDMugenBB1
          • Jan 2017
          • 20
          Originally posted by Brentsky
          It's entirely possible that the cap is still bad. It does not need to be bulging or discolored to be bad. The one I had to replace didn't look bad at all really. These aren't standard caps where the tops split and discolor. have you disconnected the board in order to rule out a shorted X-Sus and Y-Sus board ? If you have done that and the results are the same then i would replace the cap at C802. If your unable to find one I have quite a few. I can give you one. Simply cover the shipping cost which would be $2-$3 via 1st class mail
          Hey brentsky... do you have anymore of these? Mines a 223J 1250v
          • Studentske
            • Feb 2017
            • 3
            I'm having the same problem as the OP on the same model of TV ;however, when I disconnect the right hand side board and reconnected the power the TV kept continually clicking at 6 second intervals
            • bjauvin
              • Apr 2017
              Originally posted by Hamie
              Take a picture please close up and infocus of the bottom right of the powersupply
              Hi! I am BJ (new learning member) and have a similar problem. I change capacitor C802 although old one reading was at .o21uF. Did not solve problem and relay on PS board still clicking.
              So I did the test shorting pin 1 & 3 and relay click only ounce at power up and then stayed normal. This would tend to indicated an issue with PA/PK/PU/PD/PB23A EAX64696604(1.1) board... Any suggestion? Thanks in advance.
              • fix-man
                • Sep 2016
                • laos
                #67
                Ok so unplug the lead on the mainboard and put in your jumper between PSON and Stby
                Usually it's pin1 - pin3
                Hook it up like this:
                Turn on powersupply if it continues to click over and over then your power supply is at fault.
                Its more than likely will be your power supply at fault as there seems to be a common problem with C822.
                See if there is any evidence of overheating etc, as it's a known fault Id replace that first before purchasing a powersupply as it will more than likely develop the same fault eventually.
                thank you so much it's very very useful
                • junilson
                  • Jan 2019
                  • Brasil
                  #68
                  Hello, I also have a question regarding the TV 50pa4500, my model seems to be a little different, the power supply board isn't the same as the one described at this post.
                  Also, when I plug on the TV, I hear one click, followed by another click from the relay (the standby light is on). The same thing repeats after I try to turn the TV on.
                  I've opened the TV back panel and disconnected everything from the power supply board and started to connect each cable and wait out for the second click from the relay. So I first connected the cable that goes to the main board (bottom right), I just heard the first click, so I've powered off the TV and connected the cable that goes to the SUS boards (top right), but with the YSUS cable disconnected, I heard only the first click, so I've powered off the TV again and connected the YSUS cable and I heard one click, followed by the other.
                  I tried to rule out the YSUS, so I disconnected the YSUS from the Ydrive boards, so I disconnected them from the YSUS, and the same double click.
                  Could anyone help me out?
                  Thanx
                  • locksmiths
                    • Jul 2008
                    • 4
                    i look for solve the same problem....(relay clicking) then green cap on your board is c802 is it probably my problem ...because VSTP is 0v (200-206v need) and VATP is 0v (55v need) , the c802 is juste before t901 (this transformer feed VSTP and VATP.
                    • locksmiths
                      • Jul 2008
                      • 4
                      attached
                      • dkneyle
                        • Dec 2013
                        • 441
                        Originally posted by locksmiths
                        attached
                        So have you changed-out the identified capacitor?
                        • locksmiths
                          • Jul 2008
                          • 4
                          i look for a replacement parts..
                          • dkneyle
                            • Dec 2013
                            • 441
                            What country are you in? Then we might be able to direct you as to where to buy from.
                            • locksmiths
                              • Jul 2008
                              • 4
                              i buy wima 0,022uf 2000vdc 700vac from digikey, the capacitor are tight fit , i extend wires and install it.
                              plug the tv and only 1 click and the screen power up.
                              • dkneyle
                                • Dec 2013
                                • 441
                                Congratulations! You got your TV going again. That capacitor should work fine. From memory, I think it works as a coupling capacitor at either the input or the output of the switching transformer.
                                • gyn144
                                  • Jan 2022
                                  • New Zealand
                                  #76
                                  I know this is an old thread, but I just got the tv.
                                  I am trying to fix it, but couldn't find the exact capacitor.
                                  Can I use 2x 8.5nF 2kV or 3x 8.5nF 2kV to swap the C802?
                                  Thanks heaps,
                                  Gerry
                                  • tvtimmy
                                    • Mar 2015
                                    • 1160
                                    • usa
                                    #77
                                    You need a 223j 2000v capacitor (.022uf 2000v) .
                                    Ebay has tons of them
                                    • B0r1s
                                      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                      by B0r1s
                                      PSU - BN44-00878A
                                      Symptoms:
                                      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                      A weak clicking sound was coming from the transformer.
                                      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                      Progress:
                                      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                      01-17-2023, 04:58 PM
                                    • blues_spirit
                                      practical courses for troubleshooting pc motherboards
                                      by blues_spirit
                                      Hello from France,
                                      mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                      Do you think this is feasible for me? I...
                                      12-18-2022, 12:56 PM
                                    • slimmy182
                                      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                      by slimmy182
                                      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                      Looking on google I found this:...
                                      01-14-2023, 11:55 AM
                                    • beetle1303
                                      Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                      by beetle1303
                                      I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                      On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                      01-13-2025, 08:49 PM
                                    • gcrezz
                                      GV-N2060OC-6GD REV 2.0 GIGABYTE video card troubleshooting assistance needed.
                                      by gcrezz
                                      The issue with this video card is the HDMI port. Specifically on pin 19 (Diode checks on all other pins are normal). When i do a diode check on it from the pin on the board itself, I have nothing. There is also no short on the pin. Resistance reads about 200k. Normally on any HDMI pin 19 I would expect some voltage drop anywhere from .5v to 1.2v but here, I have nothing. The card is operational and can be used via the displayPort ports, but not through the HDMI. Attached you will find the pdf schematics for the card on page 22. I have verified that all of the resistors on this line before the...
                                      07-25-2024, 09:49 AM
