Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
This topic has been answered.
  • Diah
    replied
    Originally posted by bohaboha
    I have tried several codes there must be a specific code for this series of Samsung
    they are all the same over this shit samy..... yours T.CON on boards didn't start and the issue at Dc DC converter
  • bohaboha
    replied
    Originally posted by Diah
    if it response to RC then try my post 54 56 ..... and check the LVDS socket which pin have 3.3V
  • Diah
    replied
  • bohaboha
    replied
    check yours RC if it blink with yours mobile camera... easy method.. here are the diagram of the socket
    Click image for larger version  Name:	IR-WIFI-BT.jpg Views:	0 Size:	170.7 KB ID:	3545135
    When I press on on the RC STBY goes out and returns directly in the same position as if it can't start the TV so the RC works.
    I have managed to get rid of the black heatsink.
    thanks for the chart but it's not exactly the same because on my kontact pin 6,16,19 and 20 are free(not used) plus I only have a start button
  • bohaboha
    replied
    check the RC with mobile camera
    The RC is responding
  • Diah
    replied
  • Diah
    replied
    on lvds 3 and 4 have 0.4v 0.8v
    Pin 7 seems to be short but there is 3.353 on1 and 3.15 on pin 4 then i have 5.191 on pin 12 3.381 on pin 13 then 3..313 on pin15
    3.3V will generate one time only it used also by TV RC of the wifi / BT module... as well the IR so any one have short will kill this rail
  • bohaboha
    replied
    PIn 7 at STB 5V ... LVDS 3 ,4 3.3V when Tv on
    Click image for larger version Name:	20250105_132135.jpg Views:	0 Size:	1.37 MB ID:	3545110
  • Diah
    replied
  • Diah
    replied
    please can you point out the socket CN1101 and can i dot it only on stand by?
  • bohaboha
    replied
    so you don't have 5V on the socket i mentioned before...... MB replacement or the chip i mentioned to change
  • Diah
    replied
  • bohaboha
    replied
    only the point of service menu need to do it from STBY all other i wrote should the TV on.
    did the Tv response to RC ?
    -the TV does not respond to RC
  • Diah
    replied
    i did but no answer the tv does not want to start allways on STBY
  • bohaboha
    replied
    you just play as described the 2 steps.. both no need any on screen... we just do it to see if the screen turn on and display some thimgs
    replied
    I'm with you Diah, best to test everything possible. Here's the general idea of a simple reflow, using liquid flux on three sides of chip is advised and some type of accurate heat meter and some protective tape or cutout tin foil to protect any small components from blowing away or getting de-soldered: https://www.youtube.com/watch?v=FU84qGSdE-s
  • Diah
    replied
    yes, but before we go to reflow , need another testing... just in case we don't like some things going wrong with reflow then we lost.
    1- on socket CN1101 i think which it go to Wifi /BT front control LED... on pin 7 need to test if we have 5V
    2- on LVDS socket CN1300 i think... pin 3, 4 if there 3.3V... if no V. need to turn off disconnect LVDS and test the both pin with chassis if they are shorted. , if you have 3.3V then good news do following
    3- mask the pins on LVDS at MB side 12,13,14,15,16,17,18,18 , see if you get PICTURE. no picture remove the mask and so as nomoresonys suggested.
    replied
    Do Diah's tests, if no joy, maybe just use some heat from a hairdryer and gently twist the heatsink off the processor, then do a diy reflow, involves getting the solder under the chip melted so it can reattach to the chip. Pretty straight forward, there's some good how to videos on youtube. Must be careful not to overheat or it will kill the chip, not enough heat and nothing bad will happen, it just won't work is all. They recommend gradual heating then gradually take heat away so as not to thermal shock the chip. Using a temperature gauge would be advised. Need to be extra careful not to blow away or lose any of those little components nearby such as those pesky little mlc caps. Here's a rough idea of the procedure using minimal tools. If one must use a heatgun be very careful with the temps, a lot of them were not meant for the lower temps needed for this kind of work, hot air stations are a much better tool for the job: https://www.instructables.com/BGA-rework/
  • Diah
    replied
    forget to write... we do have another test for T-CON try while TV on MUTE 3 6 9 Mute
  • Diah
    replied
    Hi can not se anything on screen to handle it with the remote control
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • mrtek
    Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
    by mrtek
    Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
    11-26-2024, 09:58 AM
  • mecha1166
    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
    by mecha1166
    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
    11-25-2024, 05:22 PM
  • stinger
    Samsung UN70TU6980FXZA no sound no picture but does have backlights
    by stinger
    When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
    04-17-2024, 03:06 PM
  • mar1in
    Samsung TU8000, backlight and sound on, stuck in blue screen
    by mar1in
    I've got this Samsung here that would be stuck in a boot loop.
    After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
    Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
    Thanks in advance
    11-08-2023, 05:43 PM
