Sony OLED XR-77A80J - Initially dead, now 4 Flashes
  • thstuff
    • Jan 2015
    • 17
    A) TV initially dead
    B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
    C) Was able to perform a Reset from Settings menu and completed out of box configuration.
    D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
    E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical LED goes off, and Red Smart Core LED blinks 4 times forever. Can turn on one more time with remote and it will run for a minute before relay clicks and screen goes dark again.
    After reviewing other XR-77A80J topics, checked all connections, then performed the following Diah driven tests:
    1) Unplugged cables from power supply at CN6401 and CN6601
    2) Powered ON and measured 3.5V @ CN6401 Pin 6 STBY
    3) Jumper CN6401 Pin 6 STBY to Pin 5 POWER_ON, relay did NOT click.
    4) Added jumper from CN6401 Pin 6 STBY to Pin 1 TCON_12_ON, confirmed 12.3V present on CN6401 Pins 14-20 and CN6601 Pins 1-2
    5) Added jumper from CN6401 Pin 6 STBY to Pin 3 EVVD_ON, heard relay click, and confirmed 21.6V present on CN6601 Pins 19-30
    6) Powered OFF
    7) Reconnect cable to power supply CN6601, unplug 2 LVDS cables from right edge of T-CON
    8) Left three CN6401 jumpers in place, powered ON, heard relay click, and observed NO light, flashes, or test pattern on screen. T-Con was warm and there were no hot spots around perimeter of screen.
    9) Thought power sequencing might be an issue, so powered OFF, removed CN6401 jumpers, powered ON, jumpered Pin 6 STBY to Pin 5 POWER_ON, then Pin 1 TCON_12_ON, then Pin 3 EVVD_ON and relay clicked, but still no test pattern on screen.
    10) Power down, reconnect CN6401 and 2 LVDS cables, power up and back behavior described in E) above.
    Does this indicate a bad panel or is there some other setting required to produce the T-CON test pattern?
    Thanks!
  • Diah
    • Feb 2013
    • 6343
    remove all Jumpers you did early,,, all Kabel should be in place as it should..
    only disconnect the 21V EVDD socket between PSU and T-CON , turn on yours TV should turn on with black screen... your sign the optic port lit red and remain on.
    leave it for period of time..... plug it out from wall only
    keep evdd disconnected.., do hard reset by pressing the joystick and pull it down as you at this position plug it in wall remove the pressing only after the front LED indicator change from white to green...
    it will reboot 2-3 time leave it for long time and you can hear the first install screen melody....... at this state and its on... plug in back the evdd socket... the screen will light up and hopefully remain on
    • thstuff
      • Jan 2015
      • 17
      Diah, results...
      "remove all Jumpers you did early,,, all Kabel should be in place as it should..
      only disconnect the 21V EVDD socket between PSU and T-CON , turn on yours TV should turn on with black screen... your sign the optic port lit red and remain on."
      -> TV did not turn on and no indicator lights
      -> Waited many minutes then pressed TV power button one time, indicator flashed white one time then optic port lit Red and then indicator began to flash Red 5 times forever
      "leave it for period of time..... plug it out from wall only"
      -> Done
      "keep evdd disconnected.., do hard reset by pressing the joystick and pull it down as you at this position plug it in wall remove the pressing only after the front LED indicator change from white to green...​"
      -> This TV only has a single MB power button, so held MB power button for up to 4 minutes and never saw white or red LED indicator.
      -> Unplugged power, press and hold MB power button, connect power, release MB power button after 30 sec. One white indicator LED flash, then indicator flashes Red 5 times. (Probably panel power failure P_ID_ERR, right?)
      -> With power still ON, connected PSU EVDD CN6601, press MB power button, TV boots to select language screen. Relay clicks and screen goes dark after about 30 sec, indicator back to 4 red flashes.
      -> Press MB Power, wait for select language screen and quickly enter Self Diagnostic Function with remote buttons <Display>, <5>, <Vol ->, <Power> to capture attached photo: XR-77A08J Diagnostic Display.jpg
      Note: This TCON board has an eMMC chip which explains why no test pattern was displayed during tests in Post #1.
      • Diah
        • Feb 2013
        • 6343
        the panel have one raw OLED cells .. you can see the vertical black line near the middle.
        to keep watching this Sony ...yours option only disable the SOS pin between the T-CON and MB which it delivered via lower LVDS... you can find the pins easily... we do have here at Sony OLED how to
        • thstuff
          • Jan 2015
          • 17
          Diah, you have eyes like an Eagle I am embarrassed to have missed this important panel problem A close up of the two dead pixel columns is attached.
          1) Studying the interconnect shows MB CN6200 Pin 4 LD_ERR, but this connector is not stuffed.
          2) Lower MB LVDS CN6800 does not have a signal labeled LD_ERR, but Pin 40 is GND/ErrorDet and it goes thru a 0 Ohm SMD near the connector. Removing the 0 Ohm SMD will leave this MB input floating.
          • thstuff
            • Jan 2015
            • 17
            Put tape on flex to Lower LVDS MB CN6800 Pin 40 GND/ErrorDet. powered On, white LED flashes followed by 4 red flash. The relay does not click at all...
            Must GND/ErrorDet line on MB side be tied to 3.3V or GND when Pin 40 is taped open?
            • lotas
              • Jan 2016
              • 4459
              • Russia
              There are no errors - low level (GND), There is an error - high level (3.3V).
              • Diah
                • Feb 2013
                • 6343
                the 2 line are the issue which t-con send the sos signal to shutting down.. as perviouse post i wrote the option of blocking the signal on T-CON side only..
                the second option you have are dirty work... you need to cut the metal cover at the area you have the lines to have access to COF use tapping to see if the line went out.... or you may have shorted caps too
                search here OLED thready there are many successful work.
                also upload high resolution focused photo of yours T-CON with out any heat sink.
                • thstuff
                  • Jan 2015
                  • 17
                  Just to confirm, if Lower LVDS MB CN6800 Pin 40 GND/ErrorDet is taped, a wire must be added to MB from GND/ErrorDet to GND.
                  • Diah
                    • Feb 2013
                    • 6343
                    with yours configuration to trick MB no error there,,
                    i am talking to trick the T-CON that the panel no error had.... 2 different shoes
                    • thstuff
                      • Jan 2015
                      • 17
                      So the only way to trick the TCON is to fix COF?
                      TCON Photos as requested...
                      • Diah
                        • Feb 2013
                        • 6343
                        which screen zise this OLED ???
                        follow the rail ERROR DETECTED ON sign at t-con
                        • thstuff
                          • Jan 2015
                          • 17
                          Panel is 77"
                          • Diah
                            • Feb 2013
                            • 6343
                            Panel is 77"
                            strange at OLED world 77 and just 2 ribbon to panel.. however the pin 40 you were talking on ... i think it response to R76 or R77 on t-con ... if it was 4 ribbon then i do know.
                            • thstuff
                              • Jan 2015
                              • 17
                              When I put tape on Lower LVDS MB CN6800 Pin 40 the screen did not come on and TV went directly to 4 red flash error. Is the normal of should the screen come on?
                              • Diah
                                • Feb 2013
                                • 6343
                                i don't know what pins you are referring too... is this 40?
                                • thstuff
                                  • Jan 2015
                                  • 17
                                  Yes, MB CN6800 Pin 40 = TCON CN5 Pin 12
                                  • thstuff
                                    • Jan 2015
                                    • 17
                                    TCON CN5 Pin 12 = ERROR_DETECTION
                                    • Diah
                                      • Feb 2013
                                      • 6343
                                      i don't think yours pins calculating are correct , for me not PIN 12 maybe 7 or 8...
                                      heck the points with R i mentioned before then with ribbon socket which it go to panel
                                      c
                                      • cheebster
                                        • May 2008
                                        • 360
                                        Any success on this ?
                                        • odie34
                                          Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                          by odie34
                                          I am a hobbyist (not a professional) so please be gentle...
                                          I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                          I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                          02-18-2024, 09:11 AM
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                        • CraigR
                                          Hp x360 15-u499nr power light flashes continuously.
                                          by CraigR
                                          I have an Hp x360 15-u499nr laptop with a continuous white blinking power light. The laptop does turn on. The light flashes with just the battery and if I disconnect the battery and just use the power cord it still flashes and with both connected it still does. I have updated the bios and tried a hard reset with battery unplugged and power cord unplugged and holding down the power button for 60 seconds. I can't think of what else to try.
                                          09-16-2024, 06:12 PM
                                        • Egidio85
                                          Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                          by Egidio85
                                          Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                          the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                          the fan does not start.
                                          I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                          any advice on what to check?
                                          06-10-2025, 05:00 AM
                                        • heathloder
                                          Sony XBR-65X850E - has standby 3.3V, but won't power on - no status lights
                                          by heathloder
                                          I have a Sony XBR-65X850E that won't power on, and has no status lights.
                                          Immediately upon plugging in the TV, it tries to power up (before pressing anything). I can tell because after plugging the TV in, the main transformer on the power board begins buzzing, 2 seconds on, 2 seconds off, and it does this exactly 7 times before the TV goes back to an “OFF” state. If I press the power button on the TV, the same cycle repeats. I can confirm that no ‘status' LED's are lighting up when this happens. The backlights also do not turn on, but I can confirm that they at least “light...
                                          04-04-2020, 07:36 PM
