LG 42PJ350 Dont Turn ON only Stand by - Without Ysus & Ymain He Turn On
  • Gilera001
    • Jul 2013
    • 75
    • Deutschland
    hello all badcaps user, I have a problem with a LG 42PJ350 Plasma TV to turn on when I try him he Clickt 1x and remains in standby, if I Ysus and Ymain turn ound him Launch it works. What could it be? someone knows the problem?...
    Re: LG 42PJ350 Dont Turn ON only Stand by - Without Ysus & Ymain He Turn On
    Do you mean if you unplug the Y-sustain it will turn on?
    Y-sustain is the same as Y-main... Y-sustain is LG's name for Y board, Y-main is Samsung's name for Y board.
    • Gilera001
      • Jul 2013
      • 75
      • Deutschland
      Yes It is #right when i Unplug the y-sus the TV turn on and stay on, with the y-sustain when i push the power button he clicking and turn back to stand by replay 2 times i take a video, i hope it is easyer to understand my failure =)
      • Gilera001
        • Jul 2013
        • 75
        • Deutschland
        • Gilera001
          • Jul 2013
          • 75
          • Deutschland
          A Video from TV
          http://www.vidup.de/v/XZEl/
          http://www.vidup.de/v/gXZEl/
          • Gilera001
            • Jul 2013
            • 75
            • Deutschland
            Nobody have a idea?
            • radan
              • Jun 2014
              • 3
              • trinidad
              ln32b360c5 audio but no backlight
              • paulnetv
                • Mar 2014
                • 22
                • United Kingdom
                Gilera001 I am working on exactly the same TV right now, I have 2 of them in for repair.
                From what you describe, I think there is a fault with either the Ysus or Xsus board in the TV.
                Make sure TV is powered OFF then remove the power plugs to both Xsus & Ysus boards. Then check for continuity between the metal chassis and the fuses on the Ysus board. There are 3 fuses to check, FS201, FS202 & FS203.
                Also check continuity from chassis to the back of the two screen connectors on the Xsus board P3 & P4, as well as the main Diode D41.
                These are the most likely places where your fault will show using basic cold checks.
                If you get a continuity reading (Short Circuit) at one of these points then you have found which board is faulty.
                I Have two TV sets, the 42pj350 and the 42pj550 much the same TV but one had a faulty Xsus and the other a faulty Ysus board.
                • dopey
                  • Feb 2014
                  • devon
                  HI Paulnetv..
                  Thanks for the info...I have a 42pj550.i have continuity on my ysus and diode d41 is faulty too...does that mean i need both ysus and xsus.
                  • Gilera001
                    • Jul 2013
                    • 75
                    • Deutschland
                    halo, many thanks for the good information, all of which are sure ments ok (FS 201-202 - 203), the diode D41 has passage on both sides so I think this is broken. Can I change this? or I have to buy new Xsus and Ysus? Thanks
                    • paulnetv
                      • Mar 2014
                      • 22
                      • United Kingdom
                      dopey, I love the name I wish I had though of that one before I signed up
                      Anyway, I think you misunderstand me, Using a continuity meter, measure from the metal chassis to the points I mentioned earlier, this does not show a faulty component, it merely highlights the area within the TV which has the fault. For example, if you measure zero ohms from the metal chassis to any one of the fuses on the Ysus board, then you know the Ysus board has a fault on it which is overloading the PSU hence it immediately shutting back down, thus appearing to stay in standby.
                      This only help to narrow down which area of the TV you should be looking for the fault.
                      I must stress, that you MUST remove the connectors (particularly the power ones) from both Ysus & Xsus boards BEFORE conducting these tests as a short circuit on one board can be read via the wiring and cause you false readings on the other.
                      If you still get short circuit readings to earth/Gnd/chassis from both boards with the connectors removed then yes that does suggest you need both boards replaced or repaired.
                      D41 if I remember rightly has very low resistance resistors in parallel so reads as almost zero ohms in circuit, for this reason the same reading either side of the diode in this case does not suggest it is itself faulty.
                      Both the TV's I had in have been returned now so I have no reference boards here to confirm the following, but from memory I will try to list the parts I changed in order to repair the Xsus board and Ysus.
                      Xsus board, (EBR66607501) there is a repair kit available for this board but I managed to fix it by changing the following so maybe it's worth you check & change where necessary the following components. Q201, Q202, Q205 & Q206. These were all S/c also R121, R122 & R125 all open. Lucky for me that's all that had failed on this board, The repair kit I think contains some SMD's which I did not need, on this set there were also two popped resistors (R607 & R729) on the Ysus board (EBR66607601).
                      • Gilera001
                        • Jul 2013
                        • 75
                        • Deutschland
                        Hello, many thanks for the information, I'm sure that Ysus board is defective have another power supply tested and the tv is clicking again. Please watch the video above. Can you repair the Ysus board? and does anyone know how that goes? Thanks 4 Help
                        • Gilera001
                          • Jul 2013
                          • 75
                          • Deutschland
                          No Idea?
                          • marty-clubber
                            • Oct 2014
                            • 58
                            • u k
                            Hi does anyone know repair kit ysus board EBR66607501 from 42pj350.
                            Cheers
                            • Alastair E
                              Chief Womble
                              • Mar 2013
                              • 1963
                              • U.K.
                              Cheers
                              Well--If the usual suppliers dont list em and ebay havent any reference to any repair-kits for that board, you'll just have to check all the IGBT's etc yourself and get them as required.
                              TELEFIX
                              • marty-clubber
                                • Oct 2014
                                • 58
                                • u k
                                Ok Thank you found 4 shorted 2 30f124 2 30j124
                                Up to now mate.
                                • rapbalance
                                  • Jun 2017
                                  Where did you get these diagrams from? I found the service manual, but there was no diagrams like yours.
                                  • ajshoe
                                    ajshoe
                                    • Dec 2012
                                    • 477
                                    • usa
                                    believe paulnetv in post #11 meant Q21 Q22 Q12 Q13 (30f124 & 30J124) were shorted. These are the IGBTs that usually go bad.
                                    • smithy19840
                                      • Oct 2022
                                      • 3
                                      • australia
                                      Hi just a quick question is there an alternative I can use in place of the 2 33n25t mosfets As I have none I can use only other board i have is a lg50pk550 ysus thanks.
                                      • pajdek
                                        Lenovo Y700-17ISK turn on and off
                                        by pajdek
                                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                        09-20-2023, 02:49 AM
                                      • ThetraXXL
                                        LG OLED C1, SOS-Turn Off, Stand alone test
                                        by ThetraXXL
                                        Hello guys,
                                        I recently picked up an LG C1 in 65 inch size. Previous owner told me that the TV won‘t start, so I did believe due to PSU issue, but not this time. I could narrow it down to the T-Con or Panel.
                                        PSU and Mainboard work both like intended, all Voltages available, Optical on when T-Con lower Ribbon is disconnected and I even managed to get some picture with P-Only, IN-STOP cycle but only for 2 sec. before shutdown.
                                        For the stand alone test the panel starts with some flashing horizontal white lines and then continues to build up some color on the...
                                        10-29-2024, 10:33 AM
                                      • RdeveLabs
                                        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                        by RdeveLabs
                                        To all the members here...
                                        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                        05-05-2025, 04:59 AM
                                      • robante15
                                        Acer Aspire 4520 won't turn on after reboot
                                        by robante15
                                        Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                        It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                        The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                        If I remove the...
                                        04-06-2024, 06:50 PM
                                      • masoksian
                                        Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                        by masoksian
                                        I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                        The system does not turn on, there is no post.
                                        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                        The problem continues in the same way.
                                        I tried to turn on the Fn key, nothing came to the screen....
                                        02-15-2025, 12:08 PM
