Pioneer PDP-V402 Stand/Remote/Speakers
  • Shinju
    • Mar 2014
    • 1239
    Hey all. Long shot question!
    I am looking to complete my 4:3 RGB Plasma that I use for RGB modified classic video game consoles (NES,SNES,Neo-Geo ect).
    I am looking for these parts stateside, The stand feet (2 feet that attach to the bottom), Detachable speakers and remote.
    I got super lucky on this unit made in 2000 and only has 1600 hours of use for a commercial plasma display. Its absolutely amazing for retro games!
    Let me know, I know these parts are no going to be easy to find as this unit is 14 years old and most are probably still in use!
    Thanks!
    Re: Pioneer PDP-V402 Stand/Remote/Speakers
    A 4:3 plasma? Pictures or it didn't happen! I have never heard of that...
    (Sorry, I can't help with the parts.)
    • Shinju
      • Mar 2014
      • 1239
      Here you go!
      Here is a link to some information on it!
      http://shmups.system11.org/viewtopic.php?f=6&t=43256
      it uses BNC connections as well as VGA.
      Perfect square!
        Wow, cool! That must be tightly packed inside...
        BTW, it is still a rectangle 4 by 3, not an absolute square
        • Shinju
          • Mar 2014
          • 1239
          heh yeah yeah!
          Its a beast, and its actually quite slim considering how old it is. and Built like a tank.
          • piipo
            Old Privileg 5.1 speakers remote control question
            by piipo
            Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
            09-18-2024, 01:55 AM
          • tmhobadcap
            Pioneer VSX-522-K remote control not working???
            by tmhobadcap
            I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
            At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
            12-24-2020, 01:44 AM
            Philips F9217L-50R speakers – build quality impressions and DIY surround repair
            by momaka
            More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
            02-15-2022, 12:43 AM
          • cstout
            DeLonghi AC Remote only accepts 3V
            by cstout
            Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
            The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
            I can't find any schematics...
            06-03-2024, 03:53 PM
          • nomoresonys
            Connect pc speakers to tv without 3.5 jack
            by nomoresonys
            Currently trying to connect pc speakers to 2015 vizio tv, tv has no 3.5 headphone jack. Does have rca audio out, tried connecting thru a Y rca to 3.5 cable but getting odd results(probably just need a dac for decent audio, not sure?) not too educated on audio. With that hookup I'm getting 2 problems, can't get the speakers to increase in volume so it's very low even when turned up and when using both tv and pc speakers the pc speakers only put out the music part of the broadcast and not the vocals/talk of the program. Have you run into this before or know what it might be, Thanks.
            09-19-2025, 05:17 AM
