42PJ350 clicking noise
+ More Options
Posts
    Re: 42PJ350 clicking noise
    There's something like 20 of them! Which ones in particular?
    You can read resistor colour codes right? If not:
    https://www.google.co.uk/search?q=re...or+colour+code
    Very, very rare for resistors to fail shorted (considered unsafe, they are designed to fail open circuit.) Note, some resistors can be very low resistances, sub 1 ohm that does not make them bad.
    • marty-clubber
      • Oct 2014
      • 58
      • u k
      Thank you
      Tom
      found 6 components short ysus board, ey712,ey710,ey714,ey752,possible ey736 all fets, 2 diode open d712 d713
      checked the buffer board no shorts. tryed unplugging the buffer turn on still clicked there another way to make sure?
      going to try and order them today do they have to be exact the same hard to see some of the numbers?
      • marty-clubber
        • Oct 2014
        • 58
        • u k
        Hi
        Found these igbt off a samsung board x-main board 30F123 what would like to know compatable, need 30F124 ?
        look exactly same just different number on the end
        hope someone can help
        rgs marty
        • marty-clubber
          • Oct 2014
          • 58
          • u k
          Can anyone help ?
          • marty-clubber
            • Oct 2014
            • 58
            • u k
            Hi replaced 4 igbts blown ysus board lg42pj350 the tv powers up now the picture, colour not right any one have any idea?
            Cheers
            post pic
            • sordids999
              • May 2013
              • 2149
              #26
              http://www.ebay.co.uk/itm/LG-42-Plas...item4d251e3661
              Theres a ysus here for sale
              • marty-clubber
                • Oct 2014
                • 58
                • u k
                #27
                Hi just confirming ysus board that is faulty,going to have a go fixingfaulty componentsif any one knows repair kit great help
                thanks again guys awsum site.
                • marty-clubber
                  • Oct 2014
                  • 58
                  • u k
                  #28
                  Hi
                  does any one know where i can buy these green coated resistors having trouble finding them from the uk
                  cheers
                  • marty-clubber
                    • Oct 2014
                    • 58
                    • u k
                    #29
                    Hi Where can i find these green coated resistors can only find them with blue coating, still ok to use ?
                    same colour band as the green just want to make sure
                    rgs
                      You can use any colour body... the bands are what matters... but why are you replacing them? Resistors rarely fail without obvious marks such as burn marks or discolouration.
                      Your fault looks like Z-sustain fault.
                      • marty-clubber
                        • Oct 2014
                        • 58
                        • u k
                        #31
                        2 are short 1 measures to high
                        Definitely ysus board mate.
                        Thank you Tom for your information i will order them now
                          I've said it before. Resistors nearly never fail short (they almost always fail open), and you can get low resistance resistors. Yours are 2.2 ohm, so that is fine, for them to show shorted on a simple multimeter.
                          I really doubt they will do anything for your problem...
                          • marty-clubber
                            • Oct 2014
                            • 58
                            • u k
                            #33
                            Ok they Failed open was suppose to say sorry!
                            2x 30j124
                            2x 30f124
                            faulty all on the ysus board, Have you fixed ysus board Tom on the 42pj350 Model of the board EAX61332701 can not find repair kit.
                              What are the colour bands on them and what do they measure each
                              • marty-clubber
                                • Oct 2014
                                • 58
                                • u k
                                #35
                                Red red gold gold
                                04.7
                                04.2
                                3.47
                                cheers
                                  Red-Red-Gol-Gol = They would be expected to measure about 2.2 ohm each.
                                  So... assuming those are all on the 200 ohm range, you are getting 4.7, 4.2 and 3.5 ohm each, but those sound acceptable, considering tolerance of the resistor (5%), meter (2%), and by far the most significant effect, the zero-resistance of your meter.
                                  To measure the zero resistance of your meter, set your meter to the normal ohms range, and touch the leads together, what do you measure? I expect around 1-3 ohms for most cheap meters.
                                  • marty-clubber
                                    • Oct 2014
                                    • 58
                                    • u k
                                    #37
                                    00.1 Fluke 73
                                    just posted pic
                                      Ok, different tact... Try probing across a lead of one of the resistors (so red probe and black probe on same lead just to short them out.)
                                      • marty-clubber
                                        • Oct 2014
                                        • 58
                                        • u k
                                        #39
                                        03.7
                                        03.9
                                        4.85
                                        after shorting them out mate
                                          Eh... Just to be sure, both probes on the SAME lead of the resistor, this is just to test how well your meter probes against a resistor (contact pressure affects resistance, especially at low readings...)
                                          • NConstantinou
                                            HP Z840 workstation power supply clicking noise
                                            by NConstantinou
                                            No power
                                            i have the above ps which i change the TOP258eg ic.
                                            Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
                                            i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
                                            the colours look like R,R,W or silver,G Bl.
                                            Thanks...
                                            12-25-2024, 02:24 AM
                                          • tony359
                                            by tony359
                                            11-28-2023, 05:18 AM
                                          • MegaZAC
                                            Onkyo TX-SR805 noise in one channel
                                            by MegaZAC
                                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                            There's some logic behind it. As soon as I select an input I get only left...
                                            04-23-2025, 10:09 PM
                                          • courtcircuit
                                            Philips HTS8000 home cinema noise problem
                                            by courtcircuit
                                            Hello
                                            I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                            Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                            Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                            I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                            Removed each of tyhe boards
                                            02-08-2025, 08:22 AM
                                          • stormy90
                                            LG 42PJ350 Clicking PSU (TL;DR inside)
                                            by stormy90
                                            Hello!
                                            TL;DR: Replaced blown Q801, Q802 and fuse, but it didn't fix the problem.
                                            I'm trying to repair this TV, since it developed clicking symptom. I disconnected Y-SUS and Z-SUS boards, but PSU was still clicking, so then I was sure problem lies in PSU. When you plug it in, you can hear 2 clicks from relay and then one click when it shuts down. I found two shorted mosfets Q801, Q802 and blown fuse F801. I replaced those elements, but it's still doing the same.
                                            After some research, I found out resistors R108-113 need to be checked and sure one was showing...
                                            09-13-2020, 01:18 PM
