42PJ350 clicking noise
  • del3165
    • May 2014
    • 24
    • United Kingdom
    Hi, I have a LG 42PJ350. There seems to be a problem on the power supply (EAY60912401) the relays keep clicking and the standby light comes on then goes off continually, the voltages at connector p813 come on then go off with the clicking relay. Fuse F801 was blown. I changed the 2 mosfets Q801 AND Q802 which stopped the fuse blowing. I have removed the 2 resistors R927 and R929, both read 22ohms. I have replaced the rectifier IC301 (3BR1565JF) and checked the diode D304 and all the caps look fine. Any help would be appreciated.
  • sordids999
    • May 2013
    • 2161
    Re: 42PJ350 clicking noise
    https://www.badcaps.net/forum/showth...hlight=42PJ350
    Not sure if this will help but seems the same as yours but....
    • del3165
      • May 2014
      • 24
      • United Kingdom
      Thanks I read that post already, if I disconnect the left hand connector the relay still clicks and the tv does not come on.
      • sordids999
        • May 2013
        • 2161
        Maybe Tom66 can help
        • del3165
          • May 2014
          • 24
          • United Kingdom
          Changed ic801 l6599ad still no joy. The optical light on the control board comes on when the relay clicks then goes off. The voltage to the control board come on when it clicks then drop back to zero. There is no voltage present on the secondary.
            Do you get any brief Vs/Va voltages or are they dead?
            • del3165
              • May 2014
              • 24
              • United Kingdom
              No voltage on secondary output.
              • del3165
                • May 2014
                • 24
                • United Kingdom
                With both connector off there is 5v on the bottom right connector standby pin . The relay starts clicking when the connector is connected to the main board.
                • del3165
                  • May 2014
                  • 24
                  • United Kingdom
                  Has anyone any other ideas before I buy a power board.
                  • marty-clubber
                    • Oct 2014
                    • 58
                    • u k
                    Hi Have 42pj350 plasma tv making clicking noise removed power supply fitted new resistors r927, r929 3br1565jf regulator new diode d304.
                    but no joy still clicking.
                    any help would be appreciated new to the site
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Tried disconnecting the Y-SUS and X-SUS boards from PSU and re-testing?
                      --Whats the voltage on the Vs and Va points of PSU when you do this?
                      TELEFIX
                      • marty-clubber
                        • Oct 2014
                        • 58
                        • u k
                        Hi disconnect the ysus board tv stopped clicking
                        not sure how you check voltage have multimeter
                        • marty-clubber
                          • Oct 2014
                          • 58
                          • u k
                          Is there a repair kit y-sus board suspect it the fault ?
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            You'll need to check both Y-SUS and X-SUS for shorts......
                            TELEFIX
                            • marty-clubber
                              • Oct 2014
                              • 58
                              • u k
                              Hi took the y sus and x sus boards off which parts of the boards do i check
                              thanks marty
                              • marty-clubber
                                • Oct 2014
                                • 58
                                • u k
                                Hi checked for shorts found few blown fets on ysus board
                                diode open near transformer,do you know where i can buy replacement parts?
                                because can not find replacement board all sold out
                                cheers
                                • marty-clubber
                                  • Oct 2014
                                  • 58
                                  • u k
                                  Any one know where i can source new fets ysus board?
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    Charles Hyde and Sons or fleagay, Ohm-supplies, flat-panel TV spares (or summit) just google 'Kit' and the board number.....
                                    Most of the 'fets' will be IGBT's.....
                                    TELEFIX
                                    • marty-clubber
                                      • Oct 2014
                                      • 58
                                      • u k
                                      Thank you
                                      • marty-clubber
                                        • Oct 2014
                                        • 58
                                        • u k
                                        Hi does any on know what the green resistors are on ysus board just posted 42pj350 just found 2 that are shorted any one know where i can buy them
                                        or what they are
                                        cheers
                                        • NConstantinou
                                          HP Z840 workstation power supply clicking noise
                                          by NConstantinou
                                          No power
                                          i have the above ps which i change the TOP258eg ic.
                                          Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
                                          i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
                                          the colours look like R,R,W or silver,G Bl.
                                          Thanks...
                                          12-25-2024, 02:24 AM
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          10-03-2025, 02:18 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
