Which resistor should I remove/replace to decrease current to backlight leds?
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
    However I need some help identifying the resistor I need to replace to achieve this.
    Thank you!
  • CapLeaker
    Leaking Member
    • 8112
    Why don’t you just turn the backlight setting in the OSD down?
    • unimatrix93
      • Oct 2021
      • 343
      • Magyarország
      Good idea, but the tv doesn't have a setting for backlight brightness, only eco mode. 😅
      • CapLeaker
        Leaking Member
        • 8112
        What is the TV brand and model?
        Look at the DIM pins on the schematic. Funny thing… the TV is capable of dimming the backlights but the firmware doesn’t include that setting.
        • unimatrix93
          • Oct 2021
          • 343
          • Magyarország
          Look at the DIM pins on the schematic. Funny thing… the TV is capable of dimming the backlights but the firmware doesn't include that setting.
          It's a Phillips 49PUS6550. The mainboard is 715G6973
          • Diah
            • Feb 2013
            • 6357
            turn off the ECO mode....you will be able to adjust
            • KYBOSH
              • Oct 2011
              • 581
              • Unknown
              https://www.manua.ls/philips/49pus6551/manual?p=50
              Also shows how to adjust the brightness.
              • mikey5791
                Need help to replace burned resistor in 350w atx psu
                by mikey5791
                Hi to all forum members,
                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                12-26-2024, 04:55 AM
              • chth96
                Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                by chth96
                I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                Since then, This AC/DC adaptor have been out of order.
                But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                And Is there any possibility that it will suddenly explode as well as to be out...
                12-03-2023, 04:40 AM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • artvandalai
                What resistor ohm will work better to repair this waterpik?
                by artvandalai
                The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                01-05-2025, 04:10 PM
              • Pipolups
                Corsair K70 LUX RGB dying LEDs
                by Pipolups
                Hi there !
                I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                10-08-2024, 11:58 AM
