Sharp LC32GD4U - Multiple logic/t-con issues
  • stale
    • Nov 2024
    • 8
    Recently got this set for $15.
    When plugged in, the power light turns red as normal,
    and when powered on, the backlight immediately turns on, as does the blue power LED, but there's no other indication of startup; the input indicator sometimes shows up, but sometimes it doesn't.
    Elements of the UI seem to function; inputs can be selected and the volume can be adjusted. (I don't have the remote, so that's all I can test.)
    However, the TV seems to crash at 10-15 second intervals; certain actions, such as selecting the digital cable input or switching inputs frequently will cause it to hang. A single clicking sound can be heard near the TV's power switch at the top right. After this first crash, the TV becomes extremely finicky; sometimes, pressing the power button only causes the backlight to turn off for a split second; other times, it causes the backlight and power LED to shut off altogether. These clicks are heard at random intervals and seem to coincide with the crashes.
    When it has functioned, I've tried using the composite and HDMI ports. The TV recognizes when the input is available and when the output device is turned on, but it either displays a garbled mess (pic below) or an "incompatible video signal" error message.
    The AV composite signal I got was just a handful of green lines near the top of the screen. After these first signals, I can't get any picture at all until I've unplugged the TV and let it sit for a while; then, it's the same result.
    I'm guessing its logic board is toast. I'm going to take the TV apart tomorrow and take a look at the main board; from what I could see through the ports, it's incredibly dusty.
    What do you all think? Is this likely the issue, or is there something else at play? I'd really love to get this TV fixed - I've been trying to build a mid-2000's setup and this is the perfect model for me.
  • stale
    • Nov 2024
    • 8
    Went ahead and dismantled it today, got down to the main board and couldn't see any visual issues. Caps all look perfect, as does each PCB. Cleaned everything off
    Does anyone see anything I'm missing?
    • advant
      by advant
      02-03-2020, 12:25 AM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • Dan John
      Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0) - (Possible) Multiple Issues
      by Dan John
      Greetings everyone,
      I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
      1) On pressing the power button, the (power button) light turns on and stays on.
      2) There is no boot, or anything on the screen.
      3) The fan starts and stops a few times, then it stops completely.
      4) The light on the power button remains on.
      5) Battery not charging (original issue).
      The original problem was that the battery was not charging, but the laptop still worked. My belief
      04-23-2025, 08:12 AM
    • Stephen
      Multiple A2442 MacBook Pros 14" with the same charging issues
      by Stephen
      Same problem on all 14" MBP A2442 models we have in stock, all customers had liquid damage, All boards turn on, boards were cleaned professionally as well. Boards hold charge but batteries not charging, all show the same issue. All boards show the ORANGE AMBER light but no charge sound or any charge going in. One customer stated that the battery will charge if the lid is closed and the battery will reach 100%. USB C ports work for DATA and recognize the externals but do not recognize any charge. I have checked PPBUS_AON and we are getting 12 volts without battery, but when battery is...
      04-01-2025, 11:17 AM
