LG42LE4500 picture goes blank after few second, can only hear sound
  • Pbahuguna
    • May 2014
    • 6
    • U.k
    Hi Guys, I am looking for some real help here. I have LG 42LE4500, from past few days when I start tv it turn on fine but after few minute (10-15) picture goes blank and I can hear only sound.
    I did flash test and I can see dim picture so seem backlight is ok but very dim.
    I checked few forums and seems like its bad inverter but I don't know which one is inverter. I am attaching pics here will appreciate if any one can suggest what component I need to replace
    Kind regards
    Praveen
  • Pbahuguna
    • May 2014
    • 6
    • U.k
    Re: LG42LE4500 picture goes blank after few second, can only hear sound
    Hello guys, plese give some love to my problem as well
      • 30931
      you dont have an invertor or tubes - it's got LED backlights.
      i suspect they are powered from the 2 cables going through the top-center of the display-shield from the top-right of the power board.
      • Pbahuguna
        • May 2014
        • 6
        • U.k
        Do you think it could be problem with main board and it's worth replacing it?
          • 30931
          probably not the mainboard.
          some good power boad foto's would be a good next-step
          • audiofreak19
            • Apr 2013
            • 556
            • usa
            Yea ur inverter usually is built Into your power board.
            • audiofreak19
              • Apr 2013
              • 556
              • usa
              I had the same problem on a lcd of mine the tv would turn on just fine and show a picture but would turn off after a few minutes. I determined it was a ccfl bulb. I wonder if in this case if it could be a led gone bad. I highly doubt it but its a wonder.
              • Pbahuguna
                • May 2014
                • 6
                • U.k
                Let me know if this picture of power output pin to led help
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • jchang
                  Samsung UN70NU6900F no picture and no sound
                  by jchang
                  Hi all
                  I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                  Symptom:
                  No picture no sound.
                  When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                  No sound at all.
                  What I tried:
                  1. I tried unplugging the left or right ribbon...
                  01-09-2023, 06:28 PM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • kca
                  Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                  by kca
                  Hello all ~
                  I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                  This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                  No picture. No sound.
                  I tested all the voltages coming out of the power supply...
                  10-12-2023, 05:23 PM
