Sharp LC-40LE820M No power
+ More Options
Posts
  • bappies7
    • Aug 2011
    • 41
    Anybody of u out here have the schematics of the power board from delta electronics.
    Sharp part no : RUNTKA687WJQZ
    The LED TV have no standby light at all, completely dead.
    Check on the power board,found the 2 x main 5A fuse still not blown yet (Short).
    After much fault finding, found a short at IC7003 (MIC5209-5.0YS) between pin 1 & 2. But after removing the IC, the short is still there.
    I'm struck without the schematics.
    Any kind soul have the same problem as me before?
    Thank you.
  • bappies7
    • Aug 2011
    • 41
    Re: Sharp LC-40LE820M No power
    Anybody ????
    • Caleb
      Smokin IC's
      • Feb 2013
      • 645
      The service manual is HERE, didnt have time to look through it though so Im not sure if it will have schematics
      Some good pictures front and back of the power board would be very helpful for any of the techs on here to help you work through your power supply.
      Liberating magic smoke one part at a time
        Good pictures will help. Did you have power surge? Was this TV worked on by some one else before? just need some info to find out when the problem started.
        • bappies7
          • Aug 2011
          • 41
          Attached are the photos of the powerboard.
            Can I see the picture of the pads where IC 7003 is connected to, trying to figure out if cap c7928 is connected to one of the pin, that cap is MLCC type which will failed as shorted circuit.
              Here is the spec sheet of IC7003, as you can see, there is small filter cap on input pin 1. Pin 2 i Ground, pin 3 is the output.
              BTW, the resistance reading is <1 Ohm?
              BTW, how about the RED ROUND fuse on the left side of the board? OK?
              Never mind, that is not fuse, it is capacitor, hard to tell when pictures are not in focus.
                Can I also getting better focused and higher res pictures of the top and bottom side of the board, it is good enough for me to trace out all those traces on the board to figure out the connections.
                The whole pictures of the board and then may be in sections will be great also.
                  See the redline, it looks like the fusible resistor pads have bad solder, that fusible resistor feed the b+ from those two main filter caps to the STBY power supply section which is generated by that transformer by the barcode sticker.
                  • bappies7
                    • Aug 2011
                    • 41
                    I have removed and check c7928 it is working fine.
                    • bappies7
                      • Aug 2011
                      • 41
                      Ok will upload in a while.
                      Thanks..
                      • bappies7
                        • Aug 2011
                        • 41
                        Managed to get the power supply schematics for another model RUNTKA686WJQZ. After looking through, it looks some how similar.
                        I have removed IC7003, C7928, C7961A, D7907, R7939. And the short still exists between IN and GND of IC7003.
                        • bappies7
                          • Aug 2011
                          • 41
                          Attached are the Hi Res photos of the powerboard.
                          • bappies7
                            • Aug 2011
                            • 41
                            anybody knows.....
                            • Caleb
                              Smokin IC's
                              • Feb 2013
                              • 645
                              Usually when I cant find the source of a short I tie a current limited power source to the circuit and see what gets hot first.
                              5v source----10ohm 5w resistor---to positive, ground to negative freeze spray the board and see what melt the fastest.
                              • anbcunningham
                                • Jun 2013
                                • 8
                                bappies7 - Did you mange to get this tv working yet? I have an LC-60LE820UN that I think is having a power issue as well. When I plug the TV in, I get nothing. I'm thinking its a short on the power board, but can't seem to track it down. On your set, do you have any front panel indicators that tell you the set has power? One more question, How did you test IC7003 to determine there was a ground? Please forgive me for the novice question, I'm still learning. This is a nice (big) tv that would build my confidence if I can get it working. I bought it off craigslist for $20 in the hopes I can get it running again. Any information would be greatly appreciated!
                                BTW - I'm try to get away from just replacing boards. I want to be able to repair board level issues! It makes the task so much more enjoyable! Last night I fixed a Panasonic Plasma by replacing components on the SS board (and it worked - YEAH!!) Spent $19 for a 50" tv that was going to the dump! Now someone can use it in there house for a couple more years and keep it out of the landfill.
