Bose Lifestyle 650 remote malfunction
  • mpa2
    • May 2021
    • 15
    I'm trying to fix this RF Bose remote (model nr. 420129) for a friend. After applying supply voltage the display shows the Bose logo, after a short period of time it goes dark and the MCU enters a sleep mode. It wakes up after a key is pressed, the display remains dark all the time after the start up sequence.
    Sometimes it can still be paired with the main unit and you can control it for a short period of time, then the unit stops reacting again.
    The pcb is clean, there are no signs of corrosion. The voltages look adequate.
    I read the dump from the nvram and rewrote it several times without errors, but the problem remains.
    Maybe anyone has a working dump I could try? Or other ideas I could do?
    Thanks,
    Michael
  • Diah
    • Feb 2013
    • 6495
    with out Batteries and its cover,,, when you shuttle the remote heavily did you hear noise from inside?
    • mpa2
      • May 2021
      • 15
      well, it's completely disassembled now, there were no loose parts inside What kind of noise do you mean?
      • Diah
        • Feb 2013
        • 6495
        take a look here
        • mpa2
          • May 2021
          • 15
          No, it's a different case here. The antenna is just a trace on the pcb. All keys seem to react.
          • Diah
            • Feb 2013
            • 6495
            show please the downside
            • Diah
              • Feb 2013
              • 6495
              other things this is hand work nor robot !!
              • mpa2
                • May 2021
                • 15
                • mpa2
                  • May 2021
                  • 15
                  This was me, adding a cap in parallel for testing. Doesn't look that bad in reality
                  • Diah
                    • Feb 2013
                    • 6495
                    you have one or more keys always in contact..... carefully remove the white keys plate use alcohol up to 90% , clean the conductive lines all with it too let it dry and align the keys sheets back
                    • mpa2
                      • May 2021
                      • 15
                      Thanks, I will try it tomorrow. I actually tested the frequently used keys and the reaction of the MCU (wake up) was adequate, but I didn't check all of them. I hope I'll get this white stuff off without damaging it.
                      • Diah
                        • Feb 2013
                        • 6495
                        its glue as Mobile glass protection screen
                        • mpa2
                          • May 2021
                          • 15
                          Unfortunately, this didn't have any effect. All contacts are clean and open. Still the same behavior.
                          • Diah
                            • Feb 2013
                            • 6495
                            this is not enough.. you need to put yours DM in Amp reading in the Red + line and switch on..... remark the pulling of Am at any state even sleep and when you wake it ab
                            • mpa2
                              • May 2021
                              • 15
                              Im monitoring the current draw with the lab psu and in addition the mcu sleep/awake state with thermal imaging.
                              • Diah
                                • Feb 2013
                                • 6495
                                and did you noticed some unusual draw? by the way did it wake up on all keys
                                • mpa2
                                  • May 2021
                                  • 15
                                  Yes, after removing the white foil I tested all keys - they are all NO and closing every single one of them causes a wake up. The current draw looks fine for me - about 5 ma on start up, about 3 ma when awake and almost zero when asleep.
                                  I noticed another strange behavior. There a light switch on the buttom side, which turns on LED Backlight of the keypad and also wakes up the MCU. This wakeup works always, the LEDs however sometimes don't react.
                                  • Diah
                                    • Feb 2013
                                    • 6495
                                    can you show it here with focused clear photo
                                    • mpa2
                                      • May 2021
                                      • 15
                                      You mean the push button itself?
                                      • Diah
                                        • Feb 2013
                                        • 6495
                                        just remark it on yours photo which it show all BL working with out pressing any key
                                        • FALKLAN
                                          Mercedes-Benz W163 Bose Audio System
                                          by FALKLAN
                                          Howdy everyone!
                                          I have a SUV with a Bose audio system and I'm considering either a system upgrade, or purchasing a complete replacement system while bypassing the integrated Bose system.
                                          On the Bose side, I have not found any specifications yet. It's a decent system but I'm, at a minimum, replacing all the factory speakers, head unit and adding an amp and two 8" subs. The Bose is a 2ohm system and I'm not certain about this point. In order to use a 4ohm set of speakers (component/loud), I would need to install 2 sets of 4ohm speakers wired in parallel to match the...
                                          12-07-2023, 11:22 PM
                                        • cstout
                                          DeLonghi AC Remote only accepts 3V
                                          by cstout
                                          Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                          The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                          I can't find any schematics...
                                          06-03-2024, 03:53 PM
                                        • Mc_Millian
                                          Toshiba 50lf711u20 fire tv remote not pairing
                                          by Mc_Millian
                                          I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                          The Tv model number is: 50lf711u20 Rev B.
                                          I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                          I've tried 3 different remotes which should be fully compatible with this TV.
                                          Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                          The power button, along with the volume,back,select, and directional...
                                          04-07-2022, 12:15 PM
                                        • edugimeno
                                          HiSense 55A7500F won't obbey to remote after power on
                                          by edugimeno
                                          Hi! I have this TV set that does the following:
                                          1) I press the red power button on the remote
                                          2) The TV turns on normally
                                          3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                          4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                          Then after it's off, it would again accept the TURN ON from the remote and same again
                                          BUT:
                                          -The remote does show the correct IR beam while observed thru a phone camera
                                          -The TV works fine while using the MiRemote...
                                          03-14-2023, 11:22 AM
                                        • rustinjust
                                          Please help, where can I get a remote for my subwoofer?
                                          by rustinjust
                                          I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                          Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                          Is there...
                                          10-28-2023, 03:43 AM
