The push button for backlight is here
Bose Lifestyle 650 remote malfunction
yours harmony elite with out screen to sync feed back !! so how you put this in compare.... or i am wrong ?
Yes, harmony remote doesn't have a feedback.
I monitored today the activity on the spi interface between the transceiver and the mcu. Sometimes you can see some activity after a key press, sometimes not.
Could not find a system behind it.
I'll try to find another remote for testing.
Well, I've found another remote, which worked without any issue. So no problem on the receiver side.
I then reprogrammed the nvram of the broken one with the dump from the new one - now my friend has two functional remotes. The first thought is often the right one
Here you are!
Attached FilesPremium supporters get full download access and other benefits.
by alltvrepairsHi,
This TV came in not accept any remote functions. Have changed the IR module with a working one and still the same. I have found an SPI flash for 25L1606E for this model. Flashed it. Now I can switch on the TV with almost any Vestel remote from standby but no other remote functions work. TV works fine. I am suspecting need to update the Remote ID from the service menu but cannot enter service menu.
Any tips please? I haven't found the usb upgrade bin file online.
Panel: VES550QNDS-2D-U13
Main: 17MB130P
Thanks!
by FALKLANHowdy everyone!
I have a SUV with a Bose audio system and I'm considering either a system upgrade, or purchasing a complete replacement system while bypassing the integrated Bose system.
On the Bose side, I have not found any specifications yet. It's a decent system but I'm, at a minimum, replacing all the factory speakers, head unit and adding an amp and two 8" subs. The Bose is a 2ohm system and I'm not certain about this point. In order to use a 4ohm set of speakers (component/loud), I would need to install 2 sets of 4ohm speakers wired in parallel to match the...-
by cstoutHello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
I can't find any schematics... -
by Mc_MillianHello everyone,
I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
The Tv model number is: 50lf711u20 Rev B.
I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
I've tried 3 different remotes which should be fully compatible with this TV.
Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
The power button, along with the volume,back,select, and directional... -
by edugimenoHi! I have this TV set that does the following:
1) I press the red power button on the remote
2) The TV turns on normally
3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
Then after it's off, it would again accept the TURN ON from the remote and same again
BUT:
-The remote does show the correct IR beam while observed thru a phone camera
-The TV works fine while using the MiRemote... - Loading...
