Trying to Save - Samsung UN40MU6300 - No Signs of Life
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Originally posted by lotas
    If you had the original dump, then I fixed it for you and it should work, you can also post the t-con dump, it will be 25Q80 and what model do you have, panel number, I’ll check.
    Per your request Sir
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      What happens is you force BLon and PSon with the main board attached?
      I am not familiar with this method ...
      Can you pls explain a bit more?
      If you show me how i'll give it a try.
      • Diah
        • Feb 2013
        • 6343
        you wrote at first post you disconnected MB from PSU and LED come on... this what he mean..
        you need to use this Program SW and choice yours exact 25Q40CL and write it again with lotas file.. no more or less, also don't forget the status to write after you finish
        • CapLeaker
          Leaking Member
          • 7976
          From STBY take a 1k Ohm resistor and bridge it to PSon and BLon. Then plug the TV in. It's a bit far fetched, but I agree with lotas and Diah the MB can't boot for one reason or other. Just wondered what it does if you force it on, as the MB doesn't send any PSon and BLon to the PSU.
          • Diah
            • Feb 2013
            • 6343
            his problem he Used W25Q40BV because his program SW old one.... i give above the best one which it had W2540CL, that's all
            • CapLeaker
              Leaking Member
              • 7976
              hopefully it does the trick, as I am having the same TV here. Luckily it still works!
              • Diah
                • Feb 2013
                • 6343
                i do asked at #5 , i wish one of these come under my hand... to investigate deeply just want to know why the SPI sector 0000h - 1000h fly out
                • KYBOSH
                  • Oct 2011
                  • 581
                  • Unknown
                  #28
                  Sorry for the confusion. I used CH314A Programmer v 1.34 by SkyGZ to READ the chip using the BV profile as there was no CL profile available to choose from. I used Lotas' NeoProgrammer to write the fixed file to the chip. The NeoProgrammer has the W25Q40CL profile in it and that's the one i used to write back to the chip. Do you suspect using the software you provided will still make a difference?
                  • CapLeaker
                    Leaking Member
                    • 7976
                    well, I got one... and I am looking at it... I am using it as my monitor and not as a smart TV as such.
                    • Diah
                      • Feb 2013
                      • 6343
                      do it again withe program i give here before,, its easy job that you can do it 100 time
                      • Davi.p
                        • Sep 2009
                        • 4265
                        • Italy - Milan
                        #31
                        For me 1 blink is bad ram, i suspect, i have a main board with one bad ram chip, same 1 blink
                        • KYBOSH
                          • Oct 2011
                          • 581
                          • Unknown
                          #32
                          Sorry for the delay.
                          I'm trying to adjust the status as before but the QE radio button under the Status Register #2 is grayed out and uneditable. Everything else is the same ss the previous program. I'm not able to change the status to "42" without this. And i am using the correct chip profile (CL). What to do?
                          • Diah
                            • Feb 2013
                            • 6343
                            if you have under it the blocked tricked on theb grayed out-
                            do it as this picture.. and try use first read. if its set correct you will need nothings do or do write what ever
                            • KYBOSH
                              • Oct 2011
                              • 581
                              • Unknown
                              #34
                              This is what i have...
                              • lotas
                                • Jan 2016
                                • 4458
                                • Russia
                                #35
                                QE is not active in this program, it is a clone of the "AsProgrammer" program, in which this function is also not active, where everything works fine is "NeoProgrammer V2.2.0.10", which I posted here.
                                • Diah
                                  • Feb 2013
                                  • 6343
                                  yours problem are at yours PC... plug out yours CH from PC, just run the software... you will be able to choose the spi and edit the SREG
                                  if you cant then you have Jam at yours pc clean temps etc or use another pc
                                  • Diah
                                    • Feb 2013
                                    • 6343
                                    what are you talking.....? i use this always, no problem at all
                                    just now also with out adapter plugged in PC
                                    • lotas
                                      • Jan 2016
                                      • 4458
                                      • Russia
                                      #38
                                      It’s strange, but how did you use it, but you probably don’t know about registers, this program will show everything without a chip, and you install the chip and look.
                                      • lotas
                                        • Jan 2016
                                        • 4458
                                        • Russia
                                        #39
                                        You first need to remove the protection, that is, remove all the checkboxes, click on Write, then erase the chip, then write a dump, check the contents and then install the protection (status registers 0x88, 0x42), and also click Write.
                                        • Diah
                                          • Feb 2013
                                          • 6343
                                          i just show you it work perfectly.. other wise i will never upload to users... there are many tricks. include at the folder Devices --- StatBits.xml
                                          • KYBOSH
                                            Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                            by KYBOSH
                                            I picked this one up today.
                                            Previous owner says no signs of life.
                                            TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                            Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                            The TV model is QN65LS03BAFXZA - version: CB06
                                            The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                            I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                            Will keep you all...
                                            04-05-2025, 08:32 PM
                                            09-07-2024, 05:50 AM
                                          • Jacksoft
                                            Samsung 225MW EEPROM bootloop
                                            by Jacksoft
                                            I got an old Samsung 225MW TV with BN41-00825 motherboard.
                                            Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
                                            So I attached the VGA UART cable and read the debug data using a RT809H programmer:
                                            According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
                                            Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
                                            02-14-2025, 04:18 PM
                                            09-06-2024, 11:40 PM
