Trying to Save - Samsung UN40MU6300 - No Signs of Life
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    #41
    Originally posted by lotas
    You first need to remove the protection, that is, remove all the checkboxes, click on Write, then erase the chip, then write a dump, check the contents and then install the protection (status registers 0x88, 0x42), and also click Write.
    I did as you instructed. I disconnected the device, restarted the program, changed USB ports, started program with out device attached then reattached the device. It read the same.
    I then went in and unchecked everything in the status register (except for #3) which doesnt seem to be editable even when you try to change it. I redid everything but the QE radio button is still grayed out.
    When I disconnect the device and look at the edit screen again I see the default generic choices.
    • Diah
      • Feb 2013
      • 6500
      you have many programmer software and you put them all in one place... so the DLL will be share in PC register.... as i wrote before clean your PC.. delete all program from the place you or move then other ells,,, download CCleaner and clean Temp and Registery
      • KYBOSH
        • Oct 2011
        • 581
        • Unknown
        #43
        It occurred to me that there may be a conflict with drivers/software but I reasoned that the chances of this was slim as they were all based off of the same set of files (I assume).
        I'll try your suggestion and uninstall files and start from scratch. Im not afraid or weary to try these troubleshooting steps out. If anything we will all be more certain of what's what.
        I will try update you guys by tomorrow.
        Thank you all. Great insight.
        • lotas
          • Jan 2016
          • 4809
          • Russia
          #44
          These programs do not need to be installed on a PC (they are portable, they work from this folder where the program itself is located).
          • Diah
            • Feb 2013
            • 6500
            his problem he installed old driver.. if he plug the adapter in PC and call devices manager... he will find his CH adapter. right click on it and update driver... choose the folder Driver i gave you before it will updated the driver that all... restart pc
            • KYBOSH
              • Oct 2011
              • 581
              • Unknown
              #46
              This morning I went in and tried to figure this thing out but with no success, I uninstalled the old driver, reinstalled it and restarted the computer but the program v2.1.0.13 with unlock feature simply would not allow for selection of the the QE field on the status registers. I have no experience with SR so I dont know what to do or even where to look to try to figure out why.
              So i unstalled that set of drivers and reinstalled the drivers for NeoProgrammer (just to be on the safe side) and NeoProgrammer was able to edit the QE field. I redid everything according to lotas' instructions but when I got the chip back on the board I did not even get a solid red LED light as I did before. TV is completely unresponsive. I'll remove the chip and try it again but if that doesnt work i have 2 options. Get new EEPROM from shopjimmy or get a replacement board on the second hand market. I could have a bad RAM issue as mentioned earlier. But there are few ways for me to realistic check this without throwing money at this. At this point its a race to see how to get this unit up and running as cheaply as possible.
              I'll keep you all posted and thanks for the guidance. I am learning a lot. Any other suggestions are welcome in the meantime.
              • lotas
                • Jan 2016
                • 4809
                • Russia
                #47
                Use only the "NeoProgrammer" program, others do not work, I already wrote about this above! Now read this dump again, which you wrote down and it did not work (the SB LED did not light up) and post it here, I will look at it and a photo of reading the status register, which are currently in the chip.
                • KYBOSH
                  • Oct 2011
                  • 581
                  • Unknown
                  #48
                  YES SIR!
                  Here is the status the chip which i just pulled off the board mainboard and read again. The dump zip file is attached.
                  • lotas
                    • Jan 2016
                    • 4809
                    • Russia
                    #49
                    Originally posted by KYBOSH
                    YES SIR!
                    Everything is correct, dump is working, status registers are correct.
                    • KYBOSH
                      • Oct 2011
                      • 581
                      • Unknown
                      #50
                      Thank you for this confirmation!
                      This tells me that ordering another EEPROM will probably be a waste of time/money as the one I have is okay.
                      I'll focus my attention on other parts of the mainboard to see what I can see.
                      I'll also see if its feasible to grab another board somewhere.
                      Thanks again for all of this. Very educational!
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4518
                        • Italy - Milan
                        #51
                        remove the heatsink, test every choke inductor respect ground in volt, then post a very bright photo of main board with marked all the inductors with their voltage, .exclude those with no voltage, if you find one with 3,3v, then follow to witch condensers connects to, then solder an electrolitc cap across one, 330uF low esr or greater if you have nothing else, respect + -... i wanna make you do this experimental test, then try the tv..
                        • Diah
                          • Feb 2013
                          • 6500
                          WRONG. who dont know what and how front LED work... keep silent. and learn...
                          in general TVs have 2 style one SW switch like here in this threat , and HW DC to DC, also stop hurting other user with yours nonsense. go play at other dummy web portal
                          • KYBOSH
                            • Oct 2011
                            • 581
                            • Unknown
                            #53
                            Update: I just ordered this EEPROM and it'll be here next week hopefully.
                            When it arrives I will read the chip it and post the dump to the repository.
                            Hopefully we can discern the difference from the one we have from it.
                            Will keep you all posted.
                            • KYBOSH
                              • Oct 2011
                              • 581
                              • Unknown
                              #54
                              Here is the dump from the new SPI chip i got from ShopJimmy.
                              Unfortunately when I installed it this morning the TV still showed no signs of life at all....
                              • lotas
                                • Jan 2016
                                • 4809
                                • Russia
                                #55
                                Some kind of stan dump, why is it similar to 25Q80 (t-con (1Mb)), but read as 25Q40 (512kB).
                                • KYBOSH
                                  • Oct 2011
                                  • 581
                                  • Unknown
                                  #56
                                  I did not notice any difference until you mentioned it just now.
                                  I went back to investigate and this is what I found.​
                                  The original chip (located under the heat sink) is a 25Q40CL.
Name:	2024-12-07 10.56.18.jpg
ID:	3523399 Click image for larger version
Name:	2024-12-07 10.57.44.jpg
                                  The replacement ShopJimmy sent is a 25Q80DV
Name:	2024-12-07 10.46.05.jpg
ID:	3523401 Click image for larger version
Name:	2024-12-07 10.56.28.jpg
                                  It actually matches the other SPI chip I noted in my original post.
                                  I checked and that SPI is also a 25Q80.
Name:	Screenshot 2024-12-07 at 11.12.27 AM.png
                                  So they sent the wrong chip OR the common issue isn't with the 25Q40CL under the heat sink but rather the 25Q80DV residing at the top of the board?
                                  • lotas
                                    • Jan 2016
                                    • 4809
                                    • Russia
                                    #57
                                    25Q40 is standby mode firmware.
                                    25Q80 is T-Con firmware.
                                    They don't know what they are selling! And they don’t understand these firmwares, where each one is and what it is responsible for, and it’s not eeprom but spi flash, eeprom is 24C128, 24C256, 24C512,... (24 series).
                                    • KYBOSH
                                      • Oct 2011
                                      • 581
                                      • Unknown
                                      #58
                                      I'm actually learning a lot from you guys on this TV set!
                                      Part of this is actually my fault.
                                      firstly I did not read the description on the page thoroughly enough.
                                      https://www.shopjimmy.com/samsung-bn...n-eeprom-only/
                                      The chip they are selling (25Q80DV) that they say is the EEPROM is located at IC1603.
                                      But we have been working with IC1604 (W25Q40CL).
                                      In my excitement to get the chip on the board I did not stop to verify that they were the same.
                                      I find it hard to believe that shop.Jimmy does not know the difference between these two chips. Perhaps I should email text support to see what's going on....
                                      • KYBOSH
                                        • Oct 2011
                                        • 581
                                        • Unknown
                                        #59
                                        They don't know what they are selling! And they don't understand these firmwares, where each one is and what it is responsible for, and it's not eeprom but spi flash, eeprom is 24C128, 24C256, 24C512,... (24 series).
                                        Here is the original dump from IC1603_UT_KTN which the SJ chip said to replace.
                                        I replaced it with the new chip and will see if I get any signs of life.
                                        EDIT TO ADD:
                                        I found the S24C512-C4K33_1319 chip you mentioned in the end of your last message @ IC801.
                                        It is indeed DEAD. When I tried to read it with the NEOProgrammer I got the error msg "IC NOT RESPONDING"
                                        • lotas
                                          • Jan 2016
                                          • 4809
                                          • Russia
                                          #60
                                          Spi Flash (25Q40) and EEPROM (24C512) are completely different chips and their pinouts are also different, and this eeprom is installed in a different socket of the programmer, did you install it like that? Post a photo of how you installed this chip in the programmer and a photo of the programmer log software (screenshot).
                                          • KYBOSH
                                            Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                            by KYBOSH
                                            I picked this one up today.
                                            Previous owner says no signs of life.
                                            TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                            Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                            The TV model is QN65LS03BAFXZA - version: CB06
                                            The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                            I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                            Will keep you all...
                                            04-05-2025, 08:32 PM
                                            09-07-2024, 05:50 AM
                                          • Jacksoft
                                            Samsung 225MW EEPROM bootloop
                                            by Jacksoft
                                            I got an old Samsung 225MW TV with BN41-00825 motherboard.
                                            Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
                                            So I attached the VGA UART cable and read the debug data using a RT809H programmer:
                                            According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
                                            Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
                                            02-14-2025, 04:18 PM
                                            09-06-2024, 11:40 PM
