Philips TV 43pus7505 setting display option code, help please.
  • eurgenca
    • Nov 2013
    • 21
    • Slovenia
    Hello.
    I am dealing with a Philips TV, 43pus7505 and is stuck on boot loop.
    So I ordered a used CPU board, and now I have wired picture.
    I think the problem lies in display option code. According to SM, the command for setting
    display code is 062598 + MENU + 032 (032 is written on a label on back of a TV).
    But as soon I press the menu button TV jumps in menu. Can someone please tell me what I am doing wrong,
    or can I manually edit option code in SAM.​
  • Diah
    • Feb 2013
    • 6355
    you need inter Factory Mode
    • lotas
      • Jan 2016
      • 4542
      • Russia
      You need to find the NVM service file for your chassis and panel “43” and upload it to a usb flash drive and update the TV with this file, I don’t have a 43 diagonal, here’s an example of what file you need...
      • Diah
        • Feb 2013
        • 6355
        here other list with nvm 7500 serielll could you upload yours ?
        • lotas
          • Jan 2016
          • 4542
          • Russia
          Can...
          • Diah
            • Feb 2013
            • 6355
            Can...
            this is raw date source via NVM editor but u can use it for compare,,, but still TV option and panel ID need to write manual
            • eurgenca
              • Nov 2013
              • 21
              • Slovenia
              Hello.
              First thanks for help and replay.
              In zip file are all files that I can download from TV.
              Also, I add pictures of how display work and current config from SAM menu.
              I have no idea how to download NVM & EED files from TV.
              In nvm_ubootdat. data file I can see "panel_ID = 6", if I change this value
              and upload file, will this change the panel ID?​
              • lotas
                • Jan 2016
                • 4542
                • Russia
                Originally posted by eurgenca
                Hello.
                Try this action...
                • eurgenca
                  • Nov 2013
                  • 21
                  • Slovenia
                  No matter what button I press, I can't change panel or board ID.
                  • Diah
                    • Feb 2013
                    • 6355
                    yours zip open the file CSM_43PUS7505_12_FZ2A2047002900.txt with notepad++ and change thr Panel ID. , if yours panel ID 00X tthe only X you can change it at the SAM file too with hex editor
                    after that export the data as you did to write NVM
                    • Diah
                      • Feb 2013
                      • 6355
                      use panel ID 4 as i wrote before..so only change 6 which you have now to 4 at the 2 mentioned files
                      here changed already
                      • eurgenca
                        • Nov 2013
                        • 21
                        • Slovenia
                        I don't understand. I go to SAM select download from USB select NVM copy and EDID copy. both responded DONE, but guess what ID is still 6.
                        • Diah
                          • Feb 2013
                          • 6355
                          after writing the nvm back...need reset ti take effect
                          • lotas
                            • Jan 2016
                            • 4542
                            • Russia
                            A reset is not needed for Philips to take effect; you need to turn off the power, that is, remove the plug from the socket.
                            • eurgenca
                              • Nov 2013
                              • 21
                              • Slovenia
                              o.k. What I am doing wrong.
                              1. switch on tv and wait to boot. done.
                              2. insert usb. media player is open and msg reading files. done
                              3. enter SAM mode. done
                              4. download from USB. done
                              5. NVM copy. done
                              6. EDID copy. done
                              7. left cursor
                              8. exit SAM with st. by. done
                              9. pull the plug. done
                              wait 10s
                              10. power on TV and TADA all same.​
                              • eurgenca
                                • Nov 2013
                                • 21
                                • Slovenia
                                What will happen if I select virgin mode?
                                • eurgenca
                                  • Nov 2013
                                  • 21
                                  • Slovenia
                                  In old days, repairing things, was FUN.
                                  • Diah
                                    • Feb 2013
                                    • 6355
                                    this what written in service manual...LOL
                                    How to Store SAM Settings
                                    To store the settings changed in SAM mode (except the RGB Align settings), leave the top level SAM menu by using the POWER button on the
                                    remote control transmitter or the television se​
                                    • eurgenca
                                      • Nov 2013
                                      • 21
                                      • Slovenia
                                      Nope not working.
                                      • eurgenca
                                        • Nov 2013
                                        • 21
                                        • Slovenia
                                        O.k.
                                        Maybe I found something. There are various SSB boards, from 2k12 to 2k16 what ever this is. 2k12 - 2k15 have 40 digits option code.
                                        2k16 have 48 digits option. Command for setting option code for 2k12 to 2k15 is 062598 + MENU + 3 digits (not working for me), according to SM.
                                        For 2k16 command is 062508 + MENU + 3 digits. So tomorrow I have 2 plans.
                                        A. Try other command.
                                        B. Reset to virgin and try other command.
                                        Will see tomorrow.​
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • notallbad
                                          LG 55LM6200-TA country group/Area option
                                          by notallbad
                                          This is a 2012 LG TV so aware full functionality of the smart functions/apps will be limited however currently unable to get the LG Smart Store.
                                          Youtube, Netflix and LG Smart store icons briefly appear in the apps list but then automatically disappear after doing 'Initialisation of Premium' via the standard menu, I'm guessing this is due to the Country/Area group its set to is wrong for the UK.
                                          Unable to change the country group, Area option can be changed which alters the country group but none make any difference. So believe its the country group that needs changing....
                                          10-20-2024, 11:16 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • joelz
                                          pin Setting parameter line or set lines menu for adding ITE5571e on RT809F programmer
                                          by joelz
                                          Hi, sorry if i here to request if anyone know number of pin to set lines for reading ITE7751e on RT809F..i try to see on schematic but i dont know how to choose it..pleasee..
                                          11-18-2024, 06:02 AM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
