Sharp LC-65D64U blinking green LED
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sharp LC-65D64U blinking green LED
    It's possible, that that one side lights up brighter then the other?
      Yes, and also that odd or even bulbs not lit properly both sides.
      • tibimakai
        • Jan 2012
        • 3680
        That is the WD Live Streamer's background. The light it's even all the way.
          Lines from left to right, correct? That would be bulbs. How about a picture of a solid colour from the TV.
          • tibimakai
            • Jan 2012
            • 3680
            I don't remember seeing them there, but tomorrow I will take a picture.
            I have replaced only the master inverter board, maybe I should replace the secondary boards as well.
            I have put back the cover thinking that it's repaired, so now I will have to take it apart again.
            • tibimakai
              • Jan 2012
              • 3680
              Finally I had some time to take it apart.
              The tubes are working fine.
              To my surprise, the thin plastic sheets(light spreaders) are missing.
              I'm not sure what should be there, but the only thing covering the tubes is the thicker matte white plastic "cover". That is not enough. the lines shine though that layer.
              Where can I find these sheets? ~55" x 33" dimension I need.
              If anybody has some, I'm ready to buy it. I guess I need like two sheets, am I right?
              It's not a good idea, to use two smaller ones right?
              • tibimakai
                • Jan 2012
                • 3680
                58" x 33" I need and not 55".
                • tibimakai
                  • Jan 2012
                  • 3680
                  Anybody could sell some diffuser sheets?
                  • shahnld
                    Sony kdl 65xg9505 green amber blinking
                    by shahnld
                    Good Day.
                    I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                    i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                    green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                    01-03-2024, 03:05 PM
                  • jxrepman
                    Asus X453MA won't turn on and green led light blinking
                    by jxrepman
                    Hi there,
                    I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                    I have checked the charger and it is giving 19+ V
                    I have disconnected the battery and pressed power button for 30 seconds.
                    I tried another RAM stick.
                    Tried disconnecting the keyboard and touchpad.
                    Tried disconnecting the HDD and the wifi adapter.
                    The problem persists.
                    Hope you could help me out on this one. Thank you.
                    12-14-2024, 06:40 AM
                  • bajdik
                    Sharp LC-40LE830E white blinking after wallplug is off
                    by bajdik
                    Hello, on Sharp LC-40LE830E is everything OK. Working great. If I put the 230 V off and on again, it just blinking white standby LED. I can power on only via VOL- and CH+ and POWER button on TV. After that, I can power off and power on again without problem (by buttons or remote control) until the 230 V is connected. If i put the plug off and on again, just white standby LED blinking. TV needs three button starting again.. On the first look, the backlight looks great, no darker or lighter spots. Any idea what is wrong?
                    07-21-2023, 09:05 AM
                  • arctor
                    tv metz 55tw46 red and green blinking
                    by arctor
                    hi guys, i have a metz tv model 55tw46 solea 55-media r. when i try to turn it on the led tv blinks in red and green.i read it s a softwareproblem, i went to the site fo metz and download the firmware but also if i put the usb in the tv, it doesnt start the upgrade firmware. do you have a way to fix it? the main board have this code 613gl0960.a7...
                    03-21-2025, 01:51 AM
                  • naddaw000
                    Toshiba 55U7863DG - green light blinking (17MB130S)
                    by naddaw000
                    Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                    I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                    12-02-2023, 01:35 PM
