hi guys, i have a metz tv model 55tw46 solea 55-media r. when i try to turn it on the led tv blinks in red and green.i read it s a softwareproblem, i went to the site fo metz and download the firmware but also if i put the usb in the tv, it doesnt start the upgrade firmware. do you have a way to fix it? the main board have this code 613gl0960.a7
tv metz 55tw46 red and green blinking
by jxrepmanHi there,
I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
I have checked the charger and it is giving 19+ V
I have disconnected the battery and pressed power button for 30 seconds.
I tried another RAM stick.
Tried disconnecting the keyboard and touchpad.
Tried disconnecting the HDD and the wifi adapter.
The problem persists.
Hope you could help me out on this one. Thank you.12-14-2024, 06:40 AM -
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...02-10-2024, 02:07 PM -
by jimjoe123I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
Then each time... -
by gurj1979Hi guys.
I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
Got New chip and writes good.
THE PROBLEM...
It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
Does anyone have a Good Firmware I can have?...-
Channel: Troubleshooting & Designing Networks
by SluggerBAnyone familiar with these old Tivos and the blinking green light issue they can develop?
Someone sent me one that is exhibiting the issue, and I've been taking reading around the board and comparing them to a known good Series 3 Tivo motherboard I have, and so far the only different I can find is a difference in diode reading on a voltage regulator. However when I swap over the voltage regulator from the good Tivo to bad Tivo, it shows the diode readings of the original component, so something else is causing the issue
Power supply is good so I know it's not that.... - Loading...
