Is is possible to fix this screen ? - Grandin - UD58LGB204
+ More Options
Posts
  • mickadoum
    • Sep 2016
    • 6
    • france
    Issue with TV Display – Vertical Color Stripes on One Side (T-con board replaced, no improvement) - Grandin - UD58LGB204
    I'm experiencing an issue with my TV, and I would appreciate any insights or suggestions. Here's a description of the problem:
    • The TV shows vertical multicolored stripes on the left side of the screen, covering around 30-40% of the display.
    • The right side of the screen shows the image normally, although sometimes slightly distorted depending on the content.
    • The issue persists whether I'm displaying the TV menu or any other source, so it's not related to the input signal.
    • When I disconnect one half of the screen (through the ribbon cables), the other half works perfectly with no image issues.
    • I have already replaced the T-con board, but the problem remains unchanged.
    • There are no loose connections or faulty contacts; all ribbon cables are brand new.
    It seems like the issue could be related to the LCD panel itself or something beyond the T-con board, but I’m unsure.
    If anyone has encountered something similar or has suggestions on how to fix it, I’d really appreciate your help!
    Thank you in advance!
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Was there physical damage or trauma to the screen? Possibly somrone pressed the display near the bottom while moving it?
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • Daren87
      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
      by Daren87
      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
      08-13-2023, 03:25 PM
    • wizard13
      Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
      by wizard13
      I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
      I have checked the forum and the available documentation but could not find a solution specific to my issue.
      • Brand & Model: Dynabook Satellite Pro C50D-B-100
      • Part Number (P/N): PYU13E-00C00PFR
      • Serial Number (S/N): 22028896H
      • System Configuration (SC): A1PYU13E1127
      • Motherboard Model: IP3_ACN16_MB_V21_20211222A
      • Power Input: DC 19V –
      02-28-2025, 02:43 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
