Vizio E422VA not turning on
  • tibimakai
    • Jan 2012
    • 3680
    Re: Vizio E422VA not turning on
    I still have that board.
    You can pm me, I check in daily.
    You should give me, the exact number of the board, that you need, to compare it with mine.
    • SS454
      vizio e650i-a2 backlight flashes then turns off
      by SS454
      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
      panel: au optronics T650HVN05.4
      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
      https://www.shopjimmy.com/vizio-56-0...-power-supply/
      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
      08-20-2020, 03:57 PM
    • pedromvu
      Vizio M65-E0 not turning on
      by pedromvu
      Hi, I know these TVs are common to have problems like this, but unfortunately I was not able to find repair guide for this specific model or for something with this kind of power board.
      The thing is this doesn't have the 5vsb pin which is used to determine from which board the issue comes.
      Everything in power and main board was inspected without any apparent problems, but haven't measured everything.
      The voltages from Power to Main board are as follows:
      NC = 0
      A = 0
      BL_on/off = (Some millivolts, probably considered 0)...
      11-18-2022, 12:28 PM
    • howardc64
      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
      by howardc64
      Failure Symptom
      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
      Where is the short?
      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
      05-27-2025, 02:56 PM
    • howardc64
      Vizio SmartCast TV software bug that looks like hardware
      by howardc64
      Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
      It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
      11-16-2024, 05:17 PM
