Samsung 37" t370hw02 - distorted picture.
  • Hamie
    • Apr 2014
    • 1383
    Was up at the local recycling center yesterday dumping some smashed panels and came across this little number.
    In great condition with remote and power cable! Lucky day.
    Anyway, it has a distorted picture as below.
    Can someone tell me if it need a new logic or t-con.
    Things tried already.
    Service menu: various options tried- (info, menu, mute, power on) no real change to picture quality.
    Wiggling lvds cable: goes dark then light.
    Removing left tcon ribbon - left side back, no change right.
    Removing right tcon ribbon - right side black, left side slightly more red.
    Would I be correct in thinking the tcon is ok, and it's just a dodgy signal created by the logic board?
    Don't have a problem replacing either board but want to make sure I get the right one.
    Re: Samsung 37" t370hw02 - distorted picture.
    AS15 gamma fault on T-con board I'll guess. Picture of the T-con board please?
    • Hamie
      • Apr 2014
      • 1383
      Hello tom, thanks for your help.
      Here's the tcon.
        OK, do you see the block of test points next to the right hand ribbon marked VGAMA1, VGAMA2, etc.? Check each, noting down the voltage for each VGAMA#.
          Another one with bad AS15:
          https://www.badcaps.net/forum/showth...hlight=LN37%2A
          • Hamie
            • Apr 2014
            • 1383
            Cheers guys readings are.
            1. 15.45
            2. 15.42
            3. 15.41
            4. 15.9
            5. 13.7
            6. 10.66
            7. 12.73
            8. 13.74
            9. 8.89
            10. 7.77
            11. 7.78
            12. 14.75
            13. 14.60
            14. 14.63
            15. 14.69
            16. 13.80
            17. 12.6
            18. 9.83
            19. 11.80
            20. 12.83
            21. 14.02
            22. 14.24
            • Hamie
              • Apr 2014
              • 1383
              ok so going by toms spreadsheet it has failed miserably.
              im going to just remove the chip and replace it, i take its the small square one covered by the pad..... hope i get it the right way round!
              • Shinju
                • Mar 2014
                • 1239
                Same panel I got and same failure! What AS-15 chip do you have? AS-15 G,F ect
                • Hamie
                  • Apr 2014
                  • 1383
                  hello, unfortunately i cant read it! it had a pad stuck on it and the writting has gone.
                    You can use any AS15 to replace any AS15. And I bet it is AS15 as we have not seen this with other gamma ICs.
                    I used AS15-F to replace AS15-U for example.
                    • Hamie
                      • Apr 2014
                      • 1383
                      You were right about the chip.
                      Ok so I heat gunned off the old chip but unfortunately it took a pad with it.
                      Instead of wasting more time I ordered a new tcon from eBay (yeah I know.)
                      The new tcon arrived and the picture came back!
                      But now the picture slowly fades away after 30 seconds until the screen is completely black! The back light etc is still on.
                      I'm guessing I've bought a faulty tcon board again as the previous gamma fault picture didn't fade, what tests can i do on the new tcon to confirm if it's faulty?
                      • sordids999
                        • May 2013
                        • 2149
                        • uk
                        The same tests tom posted before
                        • Hamie
                          • Apr 2014
                          • 1383
                          yip its faulty.
                          VCOM- 6.3
                          AVDD- 15.67
                          VGH- 27.23
                          VGL- 6.29
                          1 7.61 N/A N/A N/A
                          2 7.61 7.61 0 N/A
                          3 7.61 7.61 0 Pass
                          4 7.66 7.61 0.05 Fail
                          5 7.68 7.66 0.02 Pass
                          6 7.7 7.68 0.02 Pass
                          7 7.7 7.7 0 Fail
                          8 7.7 7.7 0 Pass
                          9 7.74 7.7 0.04 Fail
                          10 7.75 7.74 0.01 Pass
                          11 7.75 7.75 0 Fail
                          12 7.75 7.75 0 Pass
                          13 6.584 7.75 -1.166 Fail
                          14 6.581 6.584 -0.003 Pass
                          15 6.577 6.581 -0.004 Pass
                          16 6.434 6.577 -0.143 Pass
                          17 6.409 6.434 -0.025 Pass
                          18 6.36 6.409 -0.049 Pass
                          19 6.287 6.36 -0.073 Pass
                          20 5.995 6.287 -0.292 Pass
                          21 5.99 5.995 -0.005 Pass
                          22 5.92 5.99 -0.07 Pass
                          • Prchallenger
                            • Jul 2016
                            Hey guys, I'm having a similar problem with the same board. It started with the same solarization and upon replacing the tcon I've got the same dark screen but now my old tcon gives just the dark screen as well. The cables seem intact and if i wiggle them, I get momentary vertical lines that then fade to black.
                            Any advice?
                            Thanks, Nick.
                            PS I wasnt sure if i should post this here or in a new thread, i can repost if I need to.
                            • Adam4791
                              • Nov 2018
                              • Azerbaijan
                              Hello. Tell me please, what voltages should be at the control points of the t-con T370HW02 BC?
                              • ducky29
                                • Dec 2015
                                • 370
                                • Europe
                                Check carefully with your finger if as chip gets hot.
                                  Just record all the voltages and tell us what you get.
                                  • ChattFix
                                    Samsung UN55TU700DFXZA Distorted Picture
                                    by ChattFix
                                    I have a Samsung UN55TU700DFXZA with a distorted picture and I thought it was a bad panel. I had a similar board with one number off and still tried it to see what the issue could be. The picture came out clear with only missing blue hue I think. I found a replacement board for $30 but wanted to learn if this would be the main IC or possibly something else. I don't have service manual so looking to learn about these cheap sets....
                                    06-02-2024, 03:50 PM
                                    09-07-2024, 05:50 AM
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • JJAAMM
                                    by JJAAMM
                                    Problem
                                    07-06-2023, 06:01 AM
                                  • shelby5041
                                    Samsung LCD TV no picture backlight on no 12v at tcon
                                    by shelby5041
                                    hi
                                    i have a samsung lcd tv
                                    it powers on with sound and backlight but no picture
                                    all voltages from PS are good 12v 3.3v and 5v
                                    whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                    i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                    no 12v at the tcon fuse
                                    i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                    the odds of having 2...
                                    10-08-2021, 08:21 AM
