Samsung QN55Q70AAFXZA Half Screen Dim
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4278
    • Italy - Milan
    I think you reported bad the power b. pins measurements, my guess is that the L is the leds line, but the H is the light sensors to the side of leds, this last is the problem, thus why the light feedback is wrong on one side? my guess is that the assembly job of the leds strips and fresnel sheets positioning puzzles the light feedback..
    ps: normally edge led strips broken in two parts are specular thus not same part
    • lotas
      • Jan 2016
      • 4503
      • Russia
      L - LOW
      H - HIGH
      Most likely one LED has two LEDs (one for low light (playing the role of darkening), the second for high light.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4278
        • Italy - Milan
        I don't think, i see the photo, only 4 pins per strip, 2 for leds, 2 for sensors
        • Diah
          • Feb 2013
          • 6354
          Originally posted by lotas
          L - LOW
          H - HIGH
          +10000
          • lotas
            • Jan 2016
            • 4503
            • Russia
            The correct 4 contacts are H+ and H- (this is the power supply for the bright ones) and L+ and L- this is the power supply for the dim LEDs.
            • Tom C
              • Sep 2024
              • 10
              Yes, you are correct. H is for the white light, L is for the blue.
              Original set are the same part number for each side. Of the original pair, one side lights only the blue, other both white and blue. The blue only strip was defective.
              I usually buy tv parts from Shop Jimmy, but they didn't stock the edge strips I needed.
              • Diah
                • Feb 2013
                • 6354
                can you upload high quality photo of the PSU from the top and down side ?
                • EazyBone
                  • Jun 2023
                  • 1306
                  • United states
                  #28
                  Yea now you know, always plug in TV before setting it back up to test the strips. Always disc main board from PSU before doing so, on Samsung anyway.
                  IF you remove the only blue strip and plug it into the other connector... And plug in see if it lights up only blue still with other connector. Maybe? I may try just to see
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4278
                    • Italy - Milan
                    #29
                    OK,, strange design, i don't know why blue leds, maybe they lit or not depends on the user settings..
                    • EazyBone
                      • Jun 2023
                      • 1306
                      • United states
                      #30
                      Blue LEDs are used for QLED tvs. They use blue LEDs and a yellow diffuser
                      • Tom C
                        • Sep 2024
                        • 10
                        The white/blue are in pairs (clear/yellow) as seen in the photo. I now know from, thanks to this forum, to power up the LEDs before reassembly.
                        Unfortunately, while moving the LCD panel, I cracked the corner. Pretty sure that’s the end for this TV.
                        I want to thank all who helped me with this project and am looking forward to being part of future discussions.
                        Tom
                        • EazyBone
                          • Jun 2023
                          • 1306
                          • United states
                          #32
                          Rip tv. Hey you learned something. I cracked the first 3 tvs I got and since then never again. Gotta learn somehow
                            • 12087
                            • U.S.
                            #33
                            Well at least it was only a samsung, might be the best that could happen...Lord only knows how much trouble that tv could have caused you.
                            • Tom C
                              • Sep 2024
                              • 10
                              Yeah, but I still enjoyed the challenge, learned something and found this forum. Win all around.
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • ohren
                                by ohren
                                09-08-2023, 05:24 PM
                              • C152Heavy
                                by C152Heavy
                                Summary for TL-DR readers:
                                • VCC pin (18) of PFC...
                                01-11-2023, 02:53 PM
                              • TheDando
                                MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
                                by TheDando
                                Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
                                10-28-2024, 06:59 PM
