Combined Main Board and T-Con Board or T-Con and LCD??
  • Pyroze
    • Apr 2014
    Does anyone know of an instance where the Manufacturer has combined the Main Board and T-Con Board or the T-Con Board and the LCD Screen? I working on a Insignia NS-50l240A13 and it seems to be a T-Con Board kind of problem yet there is no board to be found.
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: Combined Main Board and T-Con Board or T-Con and LCD??
    Yes some of the newer panels have the main board and the tcon board combined into one. Vizio televisions sometimes do this.
      Yes, like this one:
      https://www.badcaps.net/forum/showthread.php?t=37169
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
