Samsung UE65MU7003U / BN41-02568B - HDMI No Signal
  • natiz
    • Aug 2018
    • 18
    • ME
    Yes the same behavior on the new board.
    To clarify the issue, this is how it looks, no matter the port (1,2,3), the tv does not recognize a device is connected.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4333
      • Italy - Milan
      are you answering to me? please i don't see some users post because of black list, i am interested that you answer to my post n.9, have you done the fail count trick?
      And also, how can you state that there was a.power surge? Other equipements failed at same time? Bad weather?
      • CapLeaker
        Leaking Member
        • 8179
        Do you get to another similar screen "Device Detected" and want's you to do a manual setup?
        I would definitely try a different HDMI cable like a 4k cable. Depending what you use as an HDMI source, change the picture format, like size and frequency (Hz).
        • natiz
          • Aug 2018
          • 18
          • ME
          Davi.p Yes I tried removed the "fail count" pin from the connector, it didn't help. I also tried disconnecting the backlight from the psu, didn't help as well (checked with a flashlight).
          The power surge was due a lightning. It fried a sat/dvb-t receiver that was connected.
          CapLeaker I tried a couple of them, they all fail on this TV. They work on others of course. I don't get any other screen - its not detecting any thing.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4333
            • Italy - Milan
            But you did not tried all the advice, ok, i do not insist, but at least it's time to get a full keys remote, and enter to the service menu, i think you have to do first a service reset, if no changes can inspect a voice like fail count, or fail count reset, i don't know that model, can be requested to enter the advanced menu using service remote simulation by android phone+ir blaster+wav files
            • lotas
              • Jan 2016
              • 4613
              • Russia
              #26
              If you connected the hdmi cable “hot”, that is, the TV was connected to the socket and the signal device too, and when connecting the cable, a discharge could occur (HDMI is very sensitive to static) and damage the processor, at the moment after operating the TV for half an hour, the radiator is very It heats up, if so, then only replace the motherboard.
              You can use a multimeter to check the resistance relative to ground (ground) of the signal lines (differential pairs), there are 8 lines on each HDMI, there should not be short or low resistance, especially since Samsung did not install TVS diode assemblies on their inputs for protection, although there are seats .
              • Diah
                • Feb 2013
                • 6376
                still i don't think there are HW issue with original mainboards .. could be the register of the HDMI has being now blank or changed... log in service menu from Standby state and from there hard reset will register all HDMI again.
                • CapLeaker
                  Leaking Member
                  • 8179
                  CapLeaker I tried a couple of them, they all fail on this TV. They work on others of course. I don't get any other screen - it’s not detecting any thing.
                  I am in front of a 40MU6300… weird. You did a factory reset on the new board?
                  • natiz
                    • Aug 2018
                    • 18
                    • ME
                    #29
                    To close the loop here - I did try everything on the two boards that I had (factory reset, etc.).
                    Got a new power supply from ebay - still no signal on HDMI with two of the boards.
                    After getting a new board from Aliexpress (together with the new PSU, didn't bother to check the old one) - HDMI works as expected
                    Thanks all.
                    • supravit2000
                      PS4 fat has inconsistent signal after HDMI replacement
                      by supravit2000
                      Hi, guys!
                      I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
                      My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
                      12-19-2022, 08:08 PM
                    • Xristakis795
                      samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
                      by Xristakis795
                      hi to all
                      i have the above model ue40d5003
                      the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
                      when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
                      when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
                      Can you tell me from your experience...
                      02-09-2023, 03:17 PM
                    • dumpstertv
                      HDMI Inputs Have No Signal - Samsung UN65MU6290
                      by dumpstertv
                      Hi all, I have a Samsung UN65MU6290 TV, and it works fine using its internal smart TV functions but I'm unable to get signal from any of the HDMI inputs. The optical audio out works, and there's one other component jack but I don't have the cables to test that. Checking the TV's diagnostics, the "HDMI SW IC" says "NG," so I assume the main board either needs to be repaired or replaced.
                      I saw some mail-in repair services, which I'm considering, but my main question is, if I choose to go the replacement route, do I need *exactly* the same board? There are a lot...
                      01-21-2022, 02:59 PM
                    • Comp_Pro
                      PS5 HDMI not outputting CK/DA Signal
                      by Comp_Pro
                      Hello all,
                      I am trying to repair this PS5 which came in with a shorted HDMI encoder chip. This issue was not allowing the PS5 to boot and would only beep upon pressing the power button. This is the first time I've had this issue despite replacing many many HDMI ports. After installing the new chip as well as a new HDMI port the console now powers on and appears to be booting all the way but there is no video output. Looking at my HDMI tester all signals are present except for DCC Clock and DCC Data aka CK/DA on my particular tester. These two have direct connections to the encoder...
                      10-09-2023, 01:38 PM
                    • Bimad99
                      No SLP_S5 signal - SAMSUNG NP350V5C shut down while booting
                      by Bimad99
                      I have this case a SAMSUNG NP350V5C, board number is QCLA4 LA-8861P Rev : 2.0.
                      the laptop was dead because of triggered 3.3v and 5v supplies, the problem solved and the laptop fired up, I tried to boot to Linux at first but the laptop completely shuts off while booting all the times i try and it doesn't turn on only after couple hours, So i decided to change the RAM and install windows 10, the installation was successful but when it was booting to windows for the first time it shut down again, But this time it is refusing to turn on even after waiting for hours....
                      08-10-2023, 03:42 AM
