Samsung UE65MU7003U / BN41-02568B - HDMI No Signal
  • natiz
    • Aug 2018
    • 18
    • ME
    Following a power surge, the HDMI ports on a UE65MU7003U no longer work, no matter the port or the source - it shows No Signal.
    The other functions work well (eg Netflix app, etc.), its just the HDMI ports.
    Is the BN41-02568B board salvageable? Any leads before I open the heatsink cover? board replacement?
  • CapLeaker
    Leaking Member
    • 8352
    Nah. All the HDMI crap goes under the heatsink. That heatsink has to come off. Then it depends if it goes straight to the main IC or if there is an HDMI switch in between.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4540
      • Italy - Milan
      today's MB of Samsung and most of others supports almost 80% of functions in the SoC, comprised hdmi mux/decode, so the SoC is the faulty part 98%, the rest of the % is to check those 6 pins sot23-6 ic near connectors, if them are correctly fed or it's supply line is low and then them generates error in the external video source ...
      • natiz
        • Aug 2018
        • 18
        • ME
        Ok plot twist - I replaced the board - same issue - no signal on hdmis, while apps working properly.
        I checked the supply voltage from the power supply to the board, while the board was disconnected - got ~12v on all of them.
        Could the power supply be affecting the hdmi ports? Ordered one but will take some time to arrive.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4540
          • Italy - Milan
          noooo, your hands really really holed , a power supply board is easy to test , i hate this way of repairing, anyway, have you tested the video sources also with another tv?
          • natiz
            • Aug 2018
            • 18
            • ME
            Yes of course, they work properly on another tv
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4540
              • Italy - Milan
              very essy test to do: cennect everything , turn on tv , test the 13v output, if it's about 12,7v then psb is ok and you can cancel the purchase, possibilities? replacement main board also faulty, or...galloping aging and you put back original MB instead of new one.. :-(((
              • natiz
                • Aug 2018
                • 18
                • ME
                Connected the old board back. All A13V pins measure around 12.75v while tv was on and connected to hdmi source. The “fault count” pin measures about 3.3v, not sure what that means.
                The replacement board was brand new from the local samsung importer, I refuse to believe it was faulty but who knows
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4540
                  • Italy - Milan
                  We can easily examine the situation in few steps:
                  - main board is fed by only 13v line and is fully ok
                  - fail count is almost probably a signal coming from backlight ic that tells to MB to disable a faulty backlight
                  - no good reason why a fail detected by psb must stop the hdmi to work
                  -psb main ps circuit is always unable to self diagnose, or the only check i seen is the low mains output, the backlight ic usually do, the ac check tells the cpu to shut down, it does not happen..
                  final considerations: so ruled out the psb unless main ps ic has built in autodestruction routine that tells mb to go mad, but why don't implement it easier in the mb software?
                  actions: if you feel doubting this planned obsolescence is real, take a small needle, slip out the fail count wire terminal , test again tv.. or if 3v is still present onto wire, put it at ground
                    • 12330
                    • U.S.
                    I'll give the same advice as always, start simple. With the new board, If you have not already do a firmware update, no joy do a factory reset, just two simple things to try.
                    • Diah
                      • Feb 2013
                      • 6573
                      HDMI Cable damage.... change it with trusted working one.... nothings bad at your TV or source
                        • 12330
                        • U.S.
                        Good point Diah, he said he tried on another tv but wasn't specific if another cable was tried.
                        • natiz
                          • Aug 2018
                          • 18
                          • ME
                          Thanks for the advice!
                          The HDMI cable is not damaged, its not one cable or one source - all the devices/cables were tested on other TVs and are working properly.
                          with the old board connected, I disconnected the backlight cable from the psu, still no signal and "fail count" now measures around 2.3v.
                          I connected the new board, did a factory reset, setup wifi, and did a software update - same result - all hdmi ports no signal.
                          • Diah
                            • Feb 2013
                            • 6573
                            be more clear---
                            you put replacement MB and the issue same ! and what had power boards to do with HDMI if Tv working ?
                            what do you mean No HDMI... did you have sound ? did the screen remain black or it show Text No Signal..
                            BTW yours Tv HDMI version 2.0 did you used source and Cabel with same version 2.0 or yours was old one 1.4 version ?
                            • natiz
                              • Aug 2018
                              • 18
                              • ME
                              Not sure I understand the first question.
                              The tv reads “No Signal” - there is no sound and no black screen. It doesn’t recognize that there is a device connected.
                              Both cables and devices are version 2.0.
                              • Diah
                                • Feb 2013
                                • 6573
                                the first things i asked as you wrote... you replaced main boards and its same issue.... correct ?
                                did you try Tuner signal areal or sat ?
                                can you select HDMI 1 or 2 or 3 from INPUT screen ?
                                  • 12330
                                  • U.S.
                                  And you made sure that the numbers on the sticker of the new board match the old board, not just the silkscreen board numbers?
                                  • Diah
                                    • Feb 2013
                                    • 6573
                                    dont bother.... later one come and say thanks to i found the reason.... this threat just like trick.. no more from my side.
                                      • 12330
                                      • U.S.
                                      Hmmm, not sure what to think, I'd hate to think that someone is going to the trouble wasting their time, just so they can waste our time, suppose anything is possible tho.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4540
                                        • Italy - Milan
                                        Do you understand my post?
                                        • supravit2000
                                          PS4 fat has inconsistent signal after HDMI replacement
                                          by supravit2000
                                          Hi, guys!
                                          I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
                                          My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
                                          12-19-2022, 08:08 PM
                                        • Ellos
                                          Samsung s21 sim recognized but no signal
                                          by Ellos
                                          I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
                                          I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
                                          From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
                                          I think I've located the SOC that...
                                          06-27-2025, 01:31 AM
                                        • Xristakis795
                                          samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
                                          by Xristakis795
                                          hi to all
                                          i have the above model ue40d5003
                                          the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
                                          when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
                                          when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
                                          Can you tell me from your experience...
                                          02-09-2023, 03:17 PM
                                        • dumpstertv
                                          HDMI Inputs Have No Signal - Samsung UN65MU6290
                                          by dumpstertv
                                          Hi all, I have a Samsung UN65MU6290 TV, and it works fine using its internal smart TV functions but I'm unable to get signal from any of the HDMI inputs. The optical audio out works, and there's one other component jack but I don't have the cables to test that. Checking the TV's diagnostics, the "HDMI SW IC" says "NG," so I assume the main board either needs to be repaired or replaced.
                                          I saw some mail-in repair services, which I'm considering, but my main question is, if I choose to go the replacement route, do I need *exactly* the same board? There are a lot...
                                          01-21-2022, 02:59 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
