Samsung PN50B430P2DXZA
    Re: Samsung PN50B430P2DXZA
    They are pretty close, so I am not sure why you are getting different DC voltage measurements.
    • ned1
      • Feb 2014
      • 139
      • usa
      #62
      What about LED-s on control board. It appears to have 2 of them and one is constantly blinking while TV is on. Is this correct for LED-s?
        That is correct for those LEDs. About e very second flash.
        • ned1
          • Feb 2014
          • 139
          • usa
          #64
          Only one flash not both, other is off all the time
            From memory, that's what the 42" B450 I fixed did.
            • ned1
              • Feb 2014
              • 139
              • usa
              #66
              The guy who sold me x-main from eBay will ship another one. I will try that first and if 3rd one looks same then will move to something else. This tv has same picture with or without Panel orange cables disconnected from x-buffer. If still problem I will ship to you.
                Ship to me??
                • ned1
                  • Feb 2014
                  • 139
                  • usa
                  #68
                  Just kidding man
                    I'm actually interested in what might be causing this problem because it sure is bizarre. Your X-main appears to be working, your control board appears to be working and the X-buffer is OK. Only missing link is a problem with the panel but what exactly?
                    That doesn't mean I expect a half-broken 50" Samsung to end up on my doorstep. I've enough projects as it is...
                    • ned1
                      • Feb 2014
                      • 139
                      • usa
                      #70
                      I will continue working on it. Hopefully we will figure out. Appreciate your help.
                      • ned1
                        • Feb 2014
                        • 139
                        • usa
                        #71
                        Received another X-main board. This one has 0V VE. Love eBay .
                        • ned1
                          • Feb 2014
                          • 139
                          • usa
                          #72
                          What is the correct voltage reading on the orange ribbon cable that connects to the screen off the y-main board. I am reading -12V DC on each pin each connector.
                          • ned1
                            • Feb 2014
                            • 139
                            • usa
                            #73
                            • ned1
                              • Feb 2014
                              • 139
                              • usa
                              #74
                              Please see attached picture of y-main connectors. Y main VSC reads -192 but when I check any pin of orange cable from picture I am getting -12 V. Can anyone check on any plasma what voltage is there supposed to be.
                              • ned1
                                • Feb 2014
                                • 139
                                • usa
                                #75
                                One more closer picture
                                • ned1
                                  • Feb 2014
                                  • 139
                                  • usa
                                  #76
                                  Does anybody has procedure how to calibrate HDMI or AV inputs on this TV. Or does anyone has the calibration numbers that I can manually input.
                                  • Audioplus
                                    • Feb 2012
                                    • 157
                                    What was the issue, X Board, Y Board, PS, Buffers?
                                    • Jeffwal40
                                      • Apr 2015
                                      • 4
                                      • Usa
                                      #78
                                      Did you ever get it figured out???
                                        09-07-2024, 05:50 AM
                                      • TR103
                                        by TR103
                                        - it keeps rebooting
                                        01-22-2025, 04:12 PM
                                      • JJAAMM
                                        by JJAAMM
                                        Problem
                                        07-06-2023, 06:01 AM
                                      • Mgiffune
                                        by Mgiffune
                                        06-09-2024, 10:28 AM
                                      • Dodgethis
                                        Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                        by Dodgethis
                                        Hello all,
                                        This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                        09-11-2024, 07:39 AM
