technika 42-2030
  • sordids999
    • May 2013
    • 2151
    #41
    Re: technika 42-2030
    Hmm so I thought ill leave in the room for another day so put it all back together the tv is now working and you can switch it on and off very strange
      Maybe you've got an intermittent connection or fault somewhere. The fact that the TV seems to do different things independent of how it's connected or disconnected seems to suggest this.
      • sordids999
        • May 2013
        • 2151
        #43
        Yeah defo just turned it off and on back to flashing lights
        • sordids999
          • May 2013
          • 2151
          #44
          Do you think it might be worth trying a replacement board ?
            Which one?
            • sordids999
              • May 2013
              • 2151
              #46
              Main board sorry
                You got a solid picture? The panel is probably not bad.
                If you have a spare T-con try that first.
                Otherwise main board seems likely - but a few checks can be done first.
                • sordids999
                  • May 2013
                  • 2151
                  #48
                  When the tv works yes a good picture tom
                  • sordids999
                    • May 2013
                    • 2151
                    #49
                    ok tom so what test's are there we can do ?
                    • sordids999
                      • May 2013
                      • 2151
                      #50
                      any more ideas before i order a main board ?
                        Can you supply a picture of it? I'm a little busy now will be free for a detailed look, after about 5pm.
                        • sordids999
                          • May 2013
                          • 2151
                          #52
                          pictures attached main board number 17MB38-1 and thanks tom
                          • sordids999
                            • May 2013
                            • 2151
                            #53
                            ive found a board i can order if i need it Sharp LC-42CT2E main board the only thing different is the red circle ive highlighted in the picture all other connections match up im hoping it will work if i order it
                            • sordids999
                              • May 2013
                              • 2151
                              #54
                              Hi tom I've found another board for the same tv ill let u know how I get on
                                I am super busy right now with coursework, will see if I can add anything later.
                                • sordids999
                                  • May 2013
                                  • 2151
                                  #56
                                  It's ok mate course comes first I'm hoping it's the main board ill update this post later this week
                                  • sordids999
                                    • May 2013
                                    • 2151
                                    #57
                                    Ok just updating the thread replacement board arrived working ok now ...... fingers crossed
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      #58
                                      Sordids--Are you the same guy 'sordids' on ebay selling TV boards....?
                                      TELEFIX
                                      • PNI E.
                                        Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                        by PNI E.
                                        Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                        03-17-2025, 04:23 AM
                                      • cheeky2
                                        by cheeky2
                                        05-25-2024, 03:27 AM
                                      • Dani_2024
                                        by Dani_2024
                                        10-28-2024, 05:06 PM
                                      • LemoneyF
                                        Hisense 50r6- no standby, no power, bad main board?
                                        by LemoneyF
                                        Hi all
                                        I have a Hisense 50r6 that quit suddenly, immediately after turning it on. It no longer shows red a standby light and will not turn on. Completely dead.
                                        I have tested the power supply and found the following:
                                        363V and 373V across the input caps
                                        bri- 0V
                                        ana- 0V
                                        vamp-17.03V
                                        vamp-17.03V
                                        stb- 0V
                                        12V- 9.3V
                                        12V- 9.3V
                                        To the extent of my knowledge (...not far!) these numbers are normal for a Hisense power supply in a standby state, though I would like some confirmation that 9v...
                                        10-12-2022, 07:44 AM
                                      • tvguy12012012120
                                        by tvguy12012012120
                                        02-07-2025, 05:13 PM
