technika 42-2030
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: technika 42-2030
    ah it seems you have to leave it off for 5 mins then the backlight come on
    me and panels dont get on i think
      So you get picture with one ribbon out?
      • sordids999
        • May 2013
        • 2161
        • uk
        Strange both ribbons out and LVDS cable disconnected now the backlights won't boot up just orange and blue flashing standby light
          Hmm, looks like the short may have damaged the main board. What is the 17MBxx part #?
          • sordids999
            • May 2013
            • 2161
            • uk
            17mb38-1 290110
            • sordids999
              • May 2013
              • 2161
              • uk
              #26
              Ok tom both ribbons connected and back light fine if I connect the LVDS cable then it flashes orange and blue
              • sordids999
                • May 2013
                • 2161
                • uk
                #27
                Ok maybe not
                  Are you saying the fault is intermittent?
                  • sordids999
                    • May 2013
                    • 2161
                    • uk
                    #29
                    Seems to be mate one minute the back light turns on then another time its a orange and blue flashing standby
                      Hmm have you tried checking if the 12V from the PSU is steady? Maybe you have a low power supply voltage which is being loaded by the panel (but not a fault, it's normal.)
                      • sordids999
                        • May 2013
                        • 2161
                        • uk
                        #31
                        If u go back to page one tom I done a psu reading but your have to click to open it up
                        • sordids999
                          • May 2013
                          • 2161
                          • uk
                          #32
                          So you still think panel fault tom ?
                            Your PSU is working; I did not see that initially.
                            Tis an odd one, if you have 12V both ends of fuse, I am thinking something is up, somehow, with the panel. Could be a bad T-con, but it seems unlikely right now.
                            If you are willing to dive in, you might find a shorted ceramic capacitor along the panel boards.
                            Still trying to figure out why it does not work with one ribbon out - have you tried with either one removed?
                            • sordids999
                              • May 2013
                              • 2161
                              • uk
                              #34
                              I've tried removing one ribbon at a time still not working The strange bit is that I've put both ribbons back in and it's still flashing blue and orange standby it seems I have to wait a while for it to work again
                              I'll see if I can get the screen out and check the panel boards
                                • 31196
                                tesco shit,
                                if you have only 12v going into the main board,
                                and it generates the 5v & 3.3v onboard,
                                find some place to meter the 5v & 3.3v
                                then check what voltage you get in standby, and when on - with and without the lcd panel connected.
                                i'v got one here that a 23inch version,
                                there is a common problem with the 5v switching regulator breaking down under load as it warms up on the smaller ones with a msd306 board.
                                  Agreed it is Tesco shit but it does come in two flavours "China made" and "Vestel".
                                  Both are pretty bad, but at least the Vestel stuff you can get schematics for, more or less.
                                  This is a Vestel set. MSD306 is Top Victory Electronics junk..
                                  The 12V, 5V & 3.3V are all generated by the PSU.
                                  • sordids999
                                    • May 2013
                                    • 2161
                                    • uk
                                    #37
                                    Ok tom I've stripped the panel out do I need to check these tiny caps ?
                                      Just stick your meter across them, any on low ohms are suspect (<200), so note them down.
                                        • 31196
                                        made a note of that,
                                        do you know a code to get a service menu?
                                          SOURCE 3690 or SOURCE 2580 are the only ones I'm aware of.
                                          • PNI E.
                                            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                            by PNI E.
                                            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                            03-17-2025, 04:23 AM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • LemoneyF
                                            Hisense 50r6- no standby, no power, bad main board?
                                            by LemoneyF
                                            Hi all
                                            I have a Hisense 50r6 that quit suddenly, immediately after turning it on. It no longer shows red a standby light and will not turn on. Completely dead.
                                            I have tested the power supply and found the following:
                                            363V and 373V across the input caps
                                            bri- 0V
                                            ana- 0V
                                            vamp-17.03V
                                            vamp-17.03V
                                            stb- 0V
                                            12V- 9.3V
                                            12V- 9.3V
                                            To the extent of my knowledge (...not far!) these numbers are normal for a Hisense power supply in a standby state, though I would like some confirmation that 9v...
                                            10-12-2022, 07:44 AM
                                          • ygorsan
                                            by ygorsan
                                            🧩 Problem Summary:
                                            • I
                                            07-28-2025, 08:34 AM
