technika 42-2030
    Re: technika 42-2030
    Hmm so I thought ill leave in the room for another day so put it all back together the tv is now working and you can switch it on and off very strange
      Maybe you've got an intermittent connection or fault somewhere. The fact that the TV seems to do different things independent of how it's connected or disconnected seems to suggest this.
        Yeah defo just turned it off and on back to flashing lights
          Do you think it might be worth trying a replacement board ?
            Which one?
              Main board sorry
                You got a solid picture? The panel is probably not bad.
                If you have a spare T-con try that first.
                Otherwise main board seems likely - but a few checks can be done first.
                  When the tv works yes a good picture tom
                    ok tom so what test's are there we can do ?
                      any more ideas before i order a main board ?
                        Can you supply a picture of it? I'm a little busy now will be free for a detailed look, after about 5pm.
                          pictures attached main board number 17MB38-1 and thanks tom
                            ive found a board i can order if i need it Sharp LC-42CT2E main board the only thing different is the red circle ive highlighted in the picture all other connections match up im hoping it will work if i order it
                              Hi tom I've found another board for the same tv ill let u know how I get on
                                I am super busy right now with coursework, will see if I can add anything later.
                                  It's ok mate course comes first I'm hoping it's the main board ill update this post later this week
                                    Ok just updating the thread replacement board arrived working ok now ...... fingers crossed
                                      Sordids--Are you the same guy 'sordids' on ebay selling TV boards....?
                                      TELEFIX
