technika 42-2030
+ More Options
Posts
  • sordids999
    • May 2013
    • 2149
    technika 42-2030
    got this tv stuck in standby checked psu voltages very low on further testing unplugged the lvds cable from main board tv backlight comes on,so tested fuse on tcon seems ok so looking for help here pls
    thanks
  • flocko
    • Nov 2012
    • 1121
    Re: technika 42-2030
    Would think if this has the T.MSD3067.68A main board it has a bad eeprom, But could be Wrong, do not try to reset this as it will not work and could do more damage, if the main is of that above the eeprom is the one at U10 Flocko
    • sordids999
      • May 2013
      • 2149
      ok i now have backlight after removing tcon to check fuse but now have a orange standby light but still no picture ive attached the voltages im getting
      thanks for the reply flocko the main board is 17MB38-1 290110
      thanks
      • sordids999
        • May 2013
        • 2149
        ok upon reseating the lvds cable i know have backlight and a picture but when i turn it off via the buttons on the side it turns off but i now have a orange and blue flashing standby lights and you cant turn the tv back on unless you unplug the tv
          Check each end of the T-con fuse to ground for shorts.
          Use the 2000 ohm range, power to the TV unplugged.
          • sordids999
            • May 2013
            • 2149
            im not sure if i have 2000ohms on my meter ?
              What range do you use to test fuses with power off? Use that.
              • sordids999
                • May 2013
                • 2149
                i used the 200 ohm range to test the fuse unless i done this wrong
                • sordids999
                  • May 2013
                  • 2149
                  if im testing it right then when i check for shorts im getting no reading
                    OK, looks like on yours it is marked 2K, so use that.
                    • sordids999
                      • May 2013
                      • 2149
                      the tv backlight will not come on until disconnect the lvds cable from the tcon then all is fine
                      • sordids999
                        • May 2013
                        • 2149
                        @tom the tcon is LC420WUN-SCA1 6870C-0310C i have a spare but its LC420WUN-SCA1 6870C-0310A would it be ok to test ?
                          We need to see if your panel is shorting the T-con out, so a few more tests first. Should panel be OK it should be OK if all connectors are the same.
                          • sordids999
                            • May 2013
                            • 2149
                            Ok mate so what's next
                              Use the 2Kohm range. Put the black probe on the case. Red probe each end of fuse. What readings do you see? (Allow meter to settle for 10 seconds.)
                              • sordids999
                                • May 2013
                                • 2149
                                im getting no reading tom just reads 1. and thats using the 2Kohm
                                  OK, can you try powering the set on with the T-con disconnected, but the top panel ribbons removed?
                                  If it powers on - you may have a shorted panel - your choice to put in a new T-con as it may be damaged.
                                  If it does not power on as before the T-con is likely the only fault.
                                  • sordids999
                                    • May 2013
                                    • 2149
                                    ok tcon disconnected and panel ribbons removed from the T-con and yes it turned on
                                      Hmm :/ I think that may be a bad panel there. You can try with only one ribbon at a time if it has two.
                                      • sordids999
                                        • May 2013
                                        • 2149
                                        ok tried each ribbon still the same but now with both ribbon cables disconnected all im getting is a orange and blue standy lights flashing
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • LemoneyF
                                          Hisense 50r6- no standby, no power, bad main board?
                                          by LemoneyF
                                          Hi all
                                          I have a Hisense 50r6 that quit suddenly, immediately after turning it on. It no longer shows red a standby light and will not turn on. Completely dead.
                                          I have tested the power supply and found the following:
                                          363V and 373V across the input caps
                                          bri- 0V
                                          ana- 0V
                                          vamp-17.03V
                                          vamp-17.03V
                                          stb- 0V
                                          12V- 9.3V
                                          12V- 9.3V
                                          To the extent of my knowledge (...not far!) these numbers are normal for a Hisense power supply in a standby state, though I would like some confirmation that 9v...
                                          10-12-2022, 07:44 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
