LG 50PC3D Issue
  • notatvrepairguy
    • Apr 2014
    • 40
    LG 50PC3D Issue
    Hello! I recently came across this TV and decided to get my hands dirty and see what it takes to fix it while learning more about plasma tv's in the process.
    So far I've learned a ton and mostly from these forums, so thanks in advance!
    It's an LG 50pc3d UD
    I have replaced the YSUS and both YDRV / Y-buffers.
    Was a bit bummed out when I replaced the buffers, there was no change at all. They were only $21 a piece so I'm not too burnt.
    Attached is where I'm currently at, and I'm pretty baffled at this point. Pink lines, split screen.
    There is audio and clearly a picture behind it. I've tested antenna and hdmi with the same results.
    Inspected all caps etc, no visible damage or issues there.
    I'm wondering if it's loose or bad connections?
    Everything else seems to be functioning but as my username states, I am not a pro in this field.
    Any ideas? I appreciate any help I can get!
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: LG 50PC3D Issue
    I'd say logic board but let Tom66 chime in,he's the pro at plasmas.....
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      Re: LG 50PC3D Issue
      I was thinking the same thing.
      • notatvrepairguy
        • Apr 2014
        • 40
        Re: LG 50PC3D Issue
        Well if it's only a $30 part, I might just try that board as well. I'll see if anyone else agrees or has other ideas and order it Monday probably. THanks!
        • notatvrepairguy
          • Apr 2014
          • 40
          Re: LG 50PC3D Issue
          Anyone else care to chip in with some advice before I order this part? I can provide more pics if necessary, thanks!
          • notatvrepairguy
            • Apr 2014
            • 40
            Re: LG 50PC3D Issue
            I'm about to order this part but would really appreciate if anyone else could give their opinion on what they think needs to be replaced.
            Found a logic board for $30 but would really like to avoid replacing unnecessary parts if possible!
            Thanks!
              Re: LG 50PC3D Issue
              Y-sus Vsc voltage bad would be a guess; have you tried checking the Vsc and -Vy compared to panel rating? I think the control/logic is OK for now.
              • notatvrepairguy
                • Apr 2014
                • 40
                Re: LG 50PC3D Issue
                I have not, but I just replaced the YSUS last week. I got it off ebay.
                Could you give me any more info on how to test this?
                Should I contact the ebay seller about a defective part?
                Thank you for the response, I really appreciate your assistance.
                  Re: LG 50PC3D Issue
                  Can you supply a picture of your Y-sus?
                  • notatvrepairguy
                    • Apr 2014
                    • 40
                    Re: LG 50PC3D Issue
                    I'm at work right now, but if you need an "installed picture" I can get you one tonight.
                    For now, I can give you the ebay pictures from the auction I purchased if it helps.
                    http://www.ebay.com/itm/261447989535...84.m1497.l2649
                      Re: LG 50PC3D Issue
                      OK in your case Vscan tested across top and middle metal plates where the buffers connect - should be around 150V.
                      • notatvrepairguy
                        • Apr 2014
                        • 40
                        Re: LG 50PC3D Issue
                        Sorry, I'm not 100% sure what that means hahaha. Would you mind explaining a bit more?
                          Re: LG 50PC3D Issue
                          The metal plates sticking out of the Y-sus connecting to the buffers, do you see them?
                          • notatvrepairguy
                            • Apr 2014
                            • 40
                            Re: LG 50PC3D Issue
                            Yup, there are 3 of them correct?
                            The "top" referring to when its installed I assume?
                            Sorry, my electrical experience is very little. I do have a buddy who is pretty knowledgable about these things though.
                            If you could give me an idea of what tool I need and basic steps to test it I would appreciate it!
                              Re: LG 50PC3D Issue
                              You would need a digital multimeter; do you have one?
                              • notatvrepairguy
                                • Apr 2014
                                • 40
                                Re: LG 50PC3D Issue
                                I have access to one, yes.
                                  Re: LG 50PC3D Issue
                                  OK, when you can, can you send a picture of it so we know what you have and how to work with it.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Re: LG 50PC3D Issue
                                    What's your -vy voltage doing. Fluctuating perhaps?
                                    • notatvrepairguy
                                      • Apr 2014
                                      • 40
                                      Re: LG 50PC3D Issue
                                      I was going to borrow one from my parents, but I haven't gotten them to confirm that they still have it.
                                      If they don't have it, I was going to purchase this :
                                      http://www.homedepot.com/p/Klein-Too...1000/202521270
                                      Will that work? Need something better?
                                      • notatvrepairguy
                                        • Apr 2014
                                        • 40
                                        Re: LG 50PC3D Issue
                                        Found a cheaper one that I can pick on my way home tonight.
                                        Will this work?
                                        http://www.radioshack.com/product/in...ductId=4214667
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
                                        • ahmarzo
                                          Acer laptop battery draining issue
                                          by ahmarzo
                                          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                          08-02-2025, 06:39 AM
                                        • elmark
                                          HP 15-cw1002ua strange keyboard issue
                                          by elmark
                                          HP Pavilion 15-CW1002UA
                                          S/N 5CD0251CBC
                                          P/N 7KE54EA
                                          Hello guys!
                                          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                          It powers on OK and has no other issues except the following:
                                          • CAPS LOCK does not work at all
                                          • Fn button toggles Flight Mode
                                          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                          • (with SHIFT pressed: 't%' and 'y^' respectively)
                                          I initially thought it was a keyboard malfunction (internal short, etc.),
                                          but when I press and hold...
                                          06-27-2025, 01:10 AM
                                        • Simone Vergani
                                          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                          by Simone Vergani
                                          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                          To assist with troubleshooting, I'm attaching two power circuit schematics:
                                          • Power
                                          03-05-2025, 02:25 PM
