Hi
Bought this set, it had 7 blinks, SN board shorted. Replaced 4 30F131 (altough just 3 were dead) and that removed short from SN2. Powered it on and it came on for a second or two, dark/gray picture with some black horizontal stripes appeared. That changed SOS to 6 (discharging). Investigated a bit more and found Q441 (DG302) that measures around 400 ohms between 2 legs. I assumed that isn't quite normal, and it seems that was correct, because i replaced it and tv works now. It does turn on, no SOS, almost everything is fine
I noticed that picture isn't quite as it should be, it has red/green sparkles, best noticeable on gray background. On black background i can't see none. And it looks like there is some ghosting, or bad discharge, because when i enter menu, then turn it off (menu, not tv) i can still see some menu.
When tv is on, led on both SS and SN are green.
Vsus is 215V, and Vda is 58V. There are trimpots on PS for Vsus and Vda, but didn't mess with them, waiting for some ideas first
I really don't know if someone was changing some boards before i bought it, but it doesn't look like it is.
.I noticed that picture isn't quite as it should be, it has red/green sparkles, best noticeable on gray background. On black background i can't see none. And it looks like there is some ghosting, or bad discharge, because when i enter menu, then turn it off (menu, not tv) i can still see some menu.
