LG 42lg5000-za problem
  • domix
    • Jan 2014
    • 168
    • Slovenia
    I had a half screen problem, so i fixit like this one : https://www.youtube.com/watch?v=mpp14G-c9Yo
    and everything works perfect. So i had TV on and i want to take metal frame back on the tv. When i touch a metal frame whit these two board on top, the picture in a second became white, anda than this is happend like on video.
    What to do?
  • domix
    • Jan 2014
    • 168
    • Slovenia
    Re: LG 42lg5000-za problem
    I gave the metal frame one again on tv and there was smoke (picture). now i have only half of picture?
      You might have damaged the LCD panel drivers.
      • domix
        • Jan 2014
        • 168
        • Slovenia
        How to fix it?
          In this case it would probably not be repairable because the driver chips are bonded to the screen, you cannot replace them. Sorry.
          • domix
            • Jan 2014
            • 168
            • Slovenia
            This is this 8th flat cables which comes out from opanel and go on two circuts on the top of tv? Than i must to replace whole panel whit this? or i can replace only this drivers? how? can u give me some direction what can i to do?
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • Kemer
              Graphics Card mounting frame
              by Kemer
              Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
              As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
              I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
              What worries me right now is the possibility that...
              09-14-2024, 08:57 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • VikramB
              Samsung QN55LS03 | The Frame TV | Weird power cycle and restart problem
              by VikramB
              First thread here on this forum, excuse me if I miss something in my first post.
              I have the 55” variant of the Frame TV which is essentially a QLED tv. There's a weird problem where it would keep on restarting on its own. Funny thing is it might work perfectly for couple of days and then decides to go down the restart route. A few pointers:
              1. If I let the TV sit idle for a day, for the very first time it boots after that time period it usually keeps working for 5 minutes before restarting. After that it restarts every 5 seconds.
              2. I've tried the tape method and...
              03-17-2023, 02:56 PM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
