hitachi 32hxc01ua
    Re: hitachi 32hxc01ua
    You cannot really tell until you do some Voltage measurement first, replacing the LED is the last thing you will want to do.
    • Anor1412
      • Dec 2017
      • 22
      • England
      Thanks for the reply. Any suggestions where to start?
      • vinceroger69
        • Mar 2012
        • 6714
        what power supply number is used in your set as we need too test the bl-on voltages etc
        • Anor1412
          • Dec 2017
          • 22
          • England
          Hi sorry it took so long to get back to you I've been crazy busy at work I've posted the image of the details if that helps. Not sure what you meant...
            We need good clear straight shot pictures of your whole power supply board.
            • Anor1412
              • Dec 2017
              • 22
              • England
              #26
              Great! Thanks for getting back in touch I've took the picture the best I can let me know if it needs any change in light I tried to get as clear as possible. Cheers for this
              • Anor1412
                • Dec 2017
                • 22
                • England
                #27
                I have been told to jut change the LEDs is this not the best idea? I would love to be able to repair without this
                  OK, it only has one LED string, so with TV OFF, set your meter in 200VDC scale and you must leave the black probe on the chassis and the red probe on the Red wire of the LED connector, then turn on the TV while keeping and eye on the meter to see how high the Voltage will jump up to (it will happen really fast so make sure to watch the meter) and wait about 5 seconds to see how low it goes down to, then turn off the TV.
                  Move the red probe to the black wire of the LED connector and repeat the same test on this black wire then report the readings to us.
                  BTW, the number on the board is 17IPS19-5?
                  • Anor1412
                    • Dec 2017
                    • 22
                    • England
                    #29
                    Hi thanks for the reply so just done this test and the only reading I get when it settles is .455. On both red and black wires.
                    Does that make any sense to you? And yes that is correct 17IPS19-5
                      0.455V? That means the Voltage boost converter is not even getting any feeding Voltage at all.
                      Need to test all the diodes in the cold side, check all the solder joints on the bottom side of the board, try to find the schematic for the power supply if you can.
                      Can we get good clear straight shot of the whole bottom side of that power supply board?
                      https://www.badcaps.net/forum/attach...0&d=1517509257
                      What DC Voltage between the two legs of any one of the 4 caps (330uF 35V) laying on its side?
                      • Anor1412
                        • Dec 2017
                        • 22
                        • England
                        #31
                        So the DC voltage of the diodes laying on side are coming up 0.03. I've had a look and nothing jumps out at me underneath but here's the best images I can get. Thanks for this I have attached a whole picture of the underneath and 4 pictures of each quarter of the board in case they are not clear enough I'll look for the schematic
                          So what is the Voltage reading between the two legs of the those 4 caps?
                          • Anor1412
                            • Dec 2017
                            • 22
                            • England
                            #33
                            It is 0.03v
                              It is 0.03v
                              OK, it will need more in-depth troubleshooting in that power supply section.
                              BTW, just to be sure since you did not indicate if you at at least have the power indicator or not, do you?
                              • Anor1412
                                • Dec 2017
                                • 22
                                • England
                                #35
                                How do I go about this?
                                  Do you have at least power indicator?
                                    Lots of works by tracing out the circuits.
                                    • Anor1412
                                      • Dec 2017
                                      • 22
                                      • England
                                      #38
                                      Na just a multi meter... im started to think I’m pretty well unequipped for this
                                      • Anor1412
                                        • Dec 2017
                                        • 22
                                        • England
                                        #39
                                        I could try to replace the board as soon as o get the funds but a lot of them are going for quite a high price on eBay
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
