Re: hitachi 32hxc01ua
I could try to replace the board as soon as o get the funds but a lot of them are going for quite a high price on eBay
hitachi 32hxc01ua
Na just a multi meter... im started to think I’m pretty well unequipped for thisLeave a comment:
OK, it will need more in-depth troubleshooting in that power supply section.
BTW, just to be sure since you did not indicate if you at at least have the power indicator or not, do you?Last edited by budm; 02-06-2018, 12:59 PM.Leave a comment:
So the DC voltage of the diodes laying on side are coming up 0.03. I've had a look and nothing jumps out at me underneath but here's the best images I can get. Thanks for this I have attached a whole picture of the underneath and 4 pictures of each quarter of the board in case they are not clear enough I'll look for the schematicLeave a comment:
0.455V? That means the Voltage boost converter is not even getting any feeding Voltage at all.
Need to test all the diodes in the cold side, check all the solder joints on the bottom side of the board, try to find the schematic for the power supply if you can.
Can we get good clear straight shot of the whole bottom side of that power supply board?
https://www.badcaps.net/forum/attach...0&d=1517509257
What DC Voltage between the two legs of any one of the 4 caps (330uF 35V) laying on its side?Leave a comment:
What DC Voltage between the two legs of any one of the 4 caps (330uF 35V) laying on its side?Last edited by budm; 02-06-2018, 10:48 AM.Leave a comment:
OK, it only has one LED string, so with TV OFF, set your meter in 200VDC scale and you must leave the black probe on the chassis and the red probe on the Red wire of the LED connector, then turn on the TV while keeping and eye on the meter to see how high the Voltage will jump up to (it will happen really fast so make sure to watch the meter) and wait about 5 seconds to see how low it goes down to, then turn off the TV.
Move the red probe to the black wire of the LED connector and repeat the same test on this black wire then report the readings to us.
BTW, the number on the board is 17IPS19-5?
Does that make any sense to you? And yes that is correct 17IPS19-5Last edited by Anor1412; 02-06-2018, 07:16 AM.Leave a comment:
BTW, the number on the board is 17IPS19-5?Last edited by budm; 02-05-2018, 11:47 PM.Leave a comment:
I have been told to jut change the LEDs is this not the best idea? I would love to be able to repair without thisLeave a comment:
We need good clear straight shot pictures of your whole power supply board.Leave a comment:
what power supply number is used in your set as we need too test the bl-on voltages etcLeave a comment:
Thanks for the reply. Any suggestions where to start?Leave a comment:
You cannot really tell until you do some Voltage measurement first, replacing the LED is the last thing you will want to do.Leave a comment:
Hey guys on the subject of this tv I’m having trouble with mine. The backlight seems to have gone would the cause be the leds? I have done the flashlight test and you can see the menu when you shine on it. Any help would be great with this guys?Leave a comment:
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by ygorsanHi everyone,
Iām looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
š§© Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by JDCONN 100012588
Issue: No Power, Then Rebooting After Main Board Change
Short answer: replace main board and power board
Technical answer: replace main board and Q306 & Q307 on power board.
Long answer:
TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge.... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... - Loading...
