LG 42" 42LG3000 - Buzzing Inverter
  • safesurfer65
    • Feb 2014
    • 112
    • Scotland
    Hi folks
    Got a 42" LG 42LG3000 LCD tv in. Its working fine but the inverter (part no. VIT71053.51) is making a rather annoying buzzing noise. I presume replacing it will solve the problem. Any experience with this kind of issue ?
    Many thanks
    Mark
  • aar5384
    • Jan 2014
    • 82
    • England
    Re: LG 42" 42LG3000 - Buzzing Inverter
    Just to add ive been offered the same model of tv today where it wont come on for about 20 - 25 mins, basically until its warmed up
      Likely bad panel, common on these. Not aware if anyone has fixed it.
      • yesimxev
        • Feb 2016
        Did the inverter changing solved the problem? I have the same issue. Both of them make fizzing / buzzing noise.
        Hope you'll see this message
        • eccerr0r
          inverter H tree driver imbalance in an AC inverter
          by eccerr0r
          My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
          11-16-2025, 12:34 PM
        • x_orange90_x
          by x_orange90_x
          01-29-2025, 09:24 PM
        • LEECH666
          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
          by LEECH666
          Good day ladies and gentleman!
          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
          01-19-2024, 05:46 PM
        • Gentian
          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
          by Gentian
          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
          03-06-2023, 07:07 AM
        • valvashon
          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
          by valvashon
          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
          01-04-2024, 01:44 PM
