17MB15E-7 motherboard: Horrible audio whine & Intermittent startup/lockup issue
    Will upload a video shortly on this.
    About 7kHz whine from speakers (verified with scope.) Horrible noise, very audible. Also, it will not always turn on - it shows digital glitch art (random mess) on the screen when it does not. Picture is fine if it turns on, even if it makes noise. And, once set warms up hideous noise goes away.
    I checked the amp board (since it has a separate one) and the noise is present on both input & output. Ruled that out for now then. So, I checked the power supply. There's some ripple at about 420Hz, but it's only about 100mVp-p on the 24V rail so I disregarded that.
    I then went to check main board. I tried freeze spraying a few things and once I hit an LM2576T switching regulator IC223 the noise got worse...hmm...
    Checked the output, 1.77V DC on the DMM so seemed OK (rated 1.8V on schematic), maybe slightly low but nothing to write home about. So used my scope on it and I find there's about 300mVp-p noise riding on it at 30kHz. In addition to this there's a lower frequency harmonic at 7kHz being modulated into this - the same frequency as our speaker noise. Freeze spraying it alters this noise and the tone heard from the speakers.
    No wonder the CPU crashes sometimes! It's getting a supply voltage from 1.6V to 1.9V at 30kHz, it's amazing it works at all!
    Replaced capacitor C905 and the problem was fixed, both noise and glitch art, it is near IC223 and is the input capacitor for the converter. It had ESR of 34.4 ohms!
    Moral of the story is that just because a switching converter has a good output voltage doesn't mean it's working!
    Re: 17MB15E-7 motherboard: Horrible audio whine & Intermittent startup/lockup issue
    Thanks for sharing, I wonder if you can use your AC meter, you can see the AC Voltage or use Freq mode to see the AC freq. I used that method awhile back to locate bad caps on main board.
    https://www.badcaps.net/forum/showthread.php?t=31410
      I gave that a try and it didn't work on my meter (AC mode kept autoranging in and out, it does not like DC offset, frequency mode showed 0.0Hz) but it might work on a good Fluke. Meter was a B+K 2709B.
      An analog scope set free-running would work well to test for PSU noise or regulator noise.
        Yes, the scope will be the best bet to use.
          An analog scope is best for these types of ripple, that being said, digital phosphor on digital scopes is quite good these days...
          I really like the digital phosphor on my new Rigol DS1074Z scope. So much nicer, the intensity grading makes it like a real analog scope, but it has 24 million point memory, and you can pause and zoom into any point, great for intermittent faults... Considering I only paid £100 more than what I paid for my Rigol DS1102E, and it has 4 channels, I consider it a modern scope bargain.
          • tony359
            by tony359
            11-28-2023, 05:18 AM
          • MegaZAC
            Onkyo TX-SR805 noise in one channel
            by MegaZAC
            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
            There's some logic behind it. As soon as I select an input I get only left...
            04-23-2025, 10:09 PM
          • courtcircuit
            Philips HTS8000 home cinema noise problem
            by courtcircuit
            Hello
            I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
            Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
            Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
            I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
            Removed each of tyhe boards
            02-08-2025, 08:22 AM
          • LEECH666
            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
            by LEECH666
            Good day ladies and gentleman!
            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
            01-19-2024, 05:46 PM
          • roadrash
            Old PC PSU making noise etc
            by roadrash
            A vintage 1980's PC power supply has started making a hissing and whining/squealing noise and the PC is now giving random errors like memory and video etc. Ive tried the PSU with just the Motherboard plugged in and its quiet but soon as I increase the load adding controller interface cards and drives etc, the noise starts. I think there is something about to fail but cannot see anything like a bulging cap or anything. Does anyone know whats the most likely suspect component? Here is a link to a video i took....
            11-18-2025, 09:02 AM
