Techinka 46" LCD no diplay
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Techinka 46" LCD no diplay
    ive just looked again they look ok what main board does this sey use? picture and part number from the board if possible.
    • jwilliams1967
      • Apr 2014
      • 54
      hi the model number is 17pw46-4 . the picture of the board is in the first post and a schematic is a little further down . this is really frustrating me . I have now replaced all of the caps . the 2 large caps I used Panasonic . have checked for bad solders . I am a novice but do have some electronics skills from my uni days . thanks vinceroger for your help my friend
      • vinceroger69
        • Mar 2012
        • 6714
        the main board is the one with the scart socket etc on as your psu appears to have the correct voltages maybe its a problem with the main board. may be budm or tom will advise too on what next to test
        • rauno45
          • 48
          • Estonia
          Maybe a closer picture from the main board would also help? in first picture the main board is too far to make out anything that is on there.
          • jwilliams1967
            • Apr 2014
            • 54
            hi here is some more pics of the mainboard . model number is 47743236325 or 26536324 or sd1ha07 . many thanks
            • sordids999
              • May 2013
              • 2157
              #26
              Not sure if this would help but I had the same problem with my 42 inch no back light etc but the minute I disabled the LVDS cable it came on in the end a replacement main board fixed it
              • jwilliams1967
                • Apr 2014
                • 54
                #27
                have tried that .it didn't help but thanks anyway
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  this thread has the same psu and maybe main board as your how do the voltages match too yours?
                  https://www.badcaps.net/forum/showthread.php?t=23082
                  • jwilliams1967
                    • Apr 2014
                    • 54
                    #29
                    it appears that i should have about 9 volts on pin 4 . will look at this .
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Sounds like it's not detecting video input.
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • cheeky2
                        by cheeky2
                        05-25-2024, 03:27 AM
                      • Dani_2024
                        by Dani_2024
                        10-28-2024, 05:06 PM
                      • ygorsan
                        by ygorsan
                        🧩 Problem Summary:
                        • I
                        07-28-2025, 08:34 AM
                      • Asraf Atb
                        by Asraf Atb
                        01-27-2025, 05:02 PM
                      • JSin21
                        Compatibility of main boards between different variations of samsung MU6100
                        by JSin21
                        Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                        I have Samsung Smart TV UA65MU6100WXXY version DA01
                        Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                        11-27-2023, 04:54 AM
