Sony kdl46s4100 half a picture
  • AllGo'N'Show
    • Nov 2014
    • 7
    Re: Sony kdl46s4100 half a picture
    Thanks for the starting spot freak, I will dig in tomorrow in the storm and try and get started on it.
    EDIT: found a service manual should help to get started Tcon and boards available to buy or ebay for used?
    ..:: On The Repair Block ::..
    .: (1) Sony KDL-46S4100 LCD .:. (3) Samsung 206BW LCD :.
    .: Canon SD600 DigiCam (LCD) :.
    • lookimback
      • Aug 2013
      • 1489
      Panel failure is very common in that model. I had one 2 or 3 weeks ago, and a couple shortly before that. It's almost always the leftmost tab. Sometimes rightmost one though. The chip on the tab starts to come loose.
      ------------signature starts here------------
      • lookimback
        • Aug 2013
        • 1489
        I'd try disconnecting a ribbon cable from Tcon, one side at a time too. See if that has any effect. I'd still vote panel failure though. Seen too many. Try flexing the panel some too, that will usually either make the picture clear up, or go out entirely. Either way, it means a bad panel. Flexing is easier to do with the back off. If it does go out entirely, keep in mind that the picture won't come back until you cycle the power. Took me forever to figure that one out.
        • AllGo'N'Show
          • Nov 2014
          • 7
          Sweet, thanks for the tips! I see bad panel all the time and the 'temp' fix seems to work most of the time so fingers crossed hoping for the best.
          • lookimback
            • Aug 2013
            • 1489
            Next one I get, I have some new ideas to try. The temp fix works sometimes, but will eventually fail. I have a better idea than wedging something to press against the tab. My idea is to clamp the tab, across the part where the IC is, with strips of hard plastic. Maybe cut a couple strips from the housing of a TV that's been parted out. I have a basement full of them. Anyway, the idea is to apply even pressure from both sides of the tab. Enough to keep the chip firmly in contact with the tab, but not so much that you crush it. Couple small screws, one on each side, close to the tab should keep it together. Since it wouldn't be relying on the frame and backlight assembly to hold it together, it may be a more reliable fix. May have to do some trimming on the metal frame to make it fit.
            • AllGo'N'Show
              • Nov 2014
              • 7
              Is this a Sony issue for you to have this much experience with this issue or do you get alot of this model? Interesting points I will keep in mind when it comes apart! Thanks again!
              • Fly_Among_Stars
                VIZIO E70-E3 Half picture with half TCON
                by Fly_Among_Stars
                I have a VIZIO E70-E3.
                Symptoms: Black screen, no picture, but LED backlights are working.
                I probed the power board and voltages are as listed on the board.
                Main board appears fine, too.
                I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                There are two separate ribbon cables feeding the LCD.
                If both are connected, the screen is black.
                If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                04-24-2023, 08:20 PM
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • Daren87
                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                by Daren87
                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                08-13-2023, 03:25 PM
              • noisykid
                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                by noisykid
                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                12-30-2024, 07:15 PM
              • iglitare
                Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                by iglitare
                i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                Backlight seems to work, Sound (Setup menu after reset) works.
                If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                With my small knowledge i would think at least the cables are good.
                Can this happen because of a bad tcon board?
                Or is it always a bad/shorted...
                09-04-2025, 07:13 AM
