Sharp LC-52LE640U - DET_PNL12V failure
  • newtothis
    • Mar 2013
    • 1556
    • england
    #41
    Re: Sharp LC-52LE640U - DET_PNL12V failure
    Sounds to me like the panel is stuffed, Heat and cold can make thing expand and shrink which can effect temp shorts... Seems like left side is bad.
    See what others think
    • mp3car
      • Apr 2015
      • 13
      That is kind of my suspicion as well (left side panel issue), which is why I took the left side of the metal frame off the panel (carefully, as taking apart the panel itself obviously get's risky regarding structural integrity of it)...
      I am hoping that if it's a panel problem, then maybe it's a short somewhere in the ribbon wire running around the panel along the bottom and up the left side since the integrity of the glass looks fine, and it seems like a random short within a panel that isn't cracked wouldn't be a common occurence, but perhaps it is???
      If it's a faulty connection to the ribbon wires, or crimped/chaffed, then perhaps I can fix the short, and get a new t-con if I need to... However, if it's the ribbon (nearly clear - because wires are so small) between the connector interface boards (that run along the edge of the panel) and the glass itself, then I can pretty much forget fixing it... But if it's between the top and bottom connector boards, or the cable running around from the bottom up around to the left corner, then perhaps it might be fixable...
      It's just confusing though that the left side alone does not trip the error, nor the right side alone... in other words, adding the known "good side" of the panel to the mix with the suspected "bad side" makes it trip the 5-2 code, but the bad side alone doesn't... Perhaps it is something shorted in the panel and the error is only tripped with both connected because perhaps it's based on total current drawn by the ASIC or the t-con board as a whole (which means "monitoring" would be done by the PS board), AND perhaps the reason I don't no longer see the left half of the image with just the left cable connected is b/c there's now a problem with the drive after unning it for 30m, OR the short is bad enough to cause complete lack of image, even though it worked two days ago... That's the most frustrating part, it worked for 30m just fine... turned it off, now it's giving me all these issues... I was hoping I could just throw a heat sink on the t-con chip since keeping it cool seemed to keep it running...
      FYI, with the power disconnected from the t-con board, I get the same 2-5 error that I get if both outputs to the panel are connected...
      Last thought, for the moment anyhow, is wondering that if the left drive of the t-con board is shot because it overheated perhaps, then wonder if the short isn't bad enough that if I get a new t-con board and put a heat sink on the t-con's ASIC (at least I'm assuming that's what that main IC is), then perhaps it could "live" with the short, this is reason I want to swap outputs and drive the right side output of the t-con into the left side of the panel to check the left panel operation fed from a known good output channel of the t-con, but of course very short-term operation (this will test left side of panel), AND try to drive the left side output of the t-con into the right side of the panel since i know the right side of the panel is good (this will test left output of t-con)...
      In addition to my question about the pinouts of the left and right side t-con outputs being the same, is it typical for the main chip on a t-con board to get too hot to touch for any length of time? In my experience, ICs can get 'warm' to the touch of course, but if it's too hot to touch, then something is wrong, OR, it was designed for a heat-sink and it's missing...
      If anyone can answer whether the pinouts of the two outputs are the same of the t-con board are identical, and if it's typical for t-con chip to run hot, or has any other suggestions to try, it'd be a great help!!! I really hate to scrap a set that seems to be "almost" working, especially since I was "teased" with such a huge screen with a good picture for 30 minutes, the size was a big part of the tease considering my largest "modern" TV is a 50" Panasonic plasma (after PDP technology acquisition from Pioneer)...
        There are ICs in the flexible PCB that can go bad. They run hot.
        • mp3car
          • Apr 2015
          • 13
          @budm
          You think the Sharp has ICs like that too? Are those parts that can be easily obtained? It seems like boards are all over the place on the web, internal cables don't seem to be quite as easy to find from what I've seen on other threads...
          From reading other posts of yours in other threads, you seem very knowledgeable on repair... By chance do you know the answer to my question about the outputs from the t-con board being the same pinout for each half of the screen, so that I could drive the right side of the panel with the left output of the t-con board, or the left side of the panel with the right output?
          Any thought as to why it does NOT go into protect with either half by itself, but with both halves it does? Is it perhaps that it's looking at total current to the ASIC and the short isn't enough to trip it, but the short and both halves is too much? Or is it perhaps total current to the t-con board as a whole, which means the PS board would be the one to shut it down??? if the latter is true, then it makes me wonder what would happen if I forced 12V to the t-con board, but I know that's asking for trouble!
          • ggil44
            • Aug 2011
            • 105
            #45
            Hi, didn't want to give up on the bad panel issue either (LC-70LE650U).
            Maybe half of the panel failing is more common than we think.
            I would like to know how difficult it is to trace the ribbon
            cables for a possible fault. I guess it's worth the effort
            since I have nothing to loose.
            Thanks again for all the help, good advice, and information.
              The ICs are not replaceable. You need to disassemble the panel to see them. The flexible PCB is part of the LCD Glass panel, the flexible PCBs are then bonded to the rigid PCBs.
              • mp3car
                • Apr 2015
                • 13
                budm is right if the ICs he's talking about are in the "film" ribbon wire that connects the glass to the rigid PCBs that run along the sides of the panel. The PCBs along the sides are considered part of the panel and are very likely an impossible part to procure individually, let alone replace one.
                I am just going to be VERY hard to convince that it's a dead left side panel, UNLESS it died "the rest of the way" after taking ownership of it (free). As I said, it worked for me for 30 minutes the other night without issue, other than the main IC on the t-con board getting hot, I even moved the set around slightly while it was working, etc... No issues (again, other than the t-con ASIC getting very hot, btw - someone please correct me if that's not an ASIC so I don't perpetuate incorrect info). But then, I turned it off, came back the next day, no logo at startup, 0.5-5 seconds later the backlight goes out (although as I mentioned, now I can get a logo if I only connect the right side of the panel to the t-con board).
                That reminds me, regarding the 0.5 to 5s.... If it's been off for a while, when i turn it on, the backlight will run for about 5 seconds before going dark (backlight off), and then soon after give the 2-5 code. If I've been "messing with it" for a while, when I turn it on, the backlight will only run for 0.5 seconds before going dark. I am not sure if it's the same time until I get the error code or not, or if perhaps that comes quicker as well... I will do a little more "data gathering" tonight... I don't know what kind of resources you have budm, but any way you could help me determine whether I can swap the L/R sides out of the t-con board??? I am getting close to taking my chances and giving it a shot...
                • mp3car
                  • Apr 2015
                  • 13
                  Bad news, one of the ICs in the flex board/cable has "darkening" at one end... I'll try to get a picture... I realize this would be extremely difficult to replace due to the alignment required, but is it even possible to remove the flex PCB from the glass without damaging the glass?
                  • mp3car
                    • Apr 2015
                    • 13
                    definitely the flexible pcb... Impossible to purchase/replace?
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      #50
                      For the average user the answer is no.
                      There are pulse tab bonding machines that attach COF etc but they are expensive!
                      • Sus256
                        HISENSE 65E7KQ PRO - no boot
                        by Sus256
                        Hi all!
                        HISENSE 65E7KQ PRO
                        RSAG7.820.13512 - chassis
                        MT9618BAATAB - cpu
                        RSAG7.820.12059 - power
                        HD650Y3U77 - panel
                        KLM8G1GETF - emmc
                        The TV does not turn on, the standby indicator is on. All voltages are present.
                        Emms is dead. Not readable, not detected.
                        Replaced emmc.
                        But with another dump there is no launch
                        Terminal log
                        UART
                        AC_ON
                        RPMB key is not yet programmed
                        HASH1_VERSION=0x00000000 64bit
                        E-B
                        FDE enabled
                        layout pattern onebin by SAR7,0...
                        06-01-2025, 02:11 AM
                      • advant
                        by advant
                        02-03-2020, 12:25 AM
                      • sefoster
                        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                        by sefoster
                        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                        11-20-2022, 09:29 AM
                      • gavenb
                        Sharp LC-80LE661U 80 inch
                        by gavenb
                        Hi folks!
                        I have a LC-80LE661U that had some interesting issues.
                        Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                        I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                        11-12-2023, 02:05 PM
                      • ctroxtell
                        Carrier HK50AA063 display controller common failure help
                        by ctroxtell
                        I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                        02-05-2025, 05:31 PM
