LG 50PT350 Help
  • Bobabrett
    • Apr 2014
    • 15
    Re: LG 50PT350 Help
    I'm an electronics noob, so even if I was able to measure, I would doubt my own accuracy. What are the chances or what would be the signs that it was the Y-board?
    best,
    Brett
    • mmartell
      • Oct 2013
      • 3189
      Re: LG 50PT350 Help
      A faulty Y board would certainly make the pic go out but to have it come back on again... I can't tell you to replace the Y board as with the information you've provided that's just a crap shoot.
      • Bobabrett
        • Apr 2014
        • 15
        Re: LG 50PT350 Help
        Just in case any of you were following along at home---I replaced the Y Control board and everything works like clockwork!
        • Gibson1986
          • Sep 2014
          • 10
          Re: LG 50PT350 Help
          Help.. I'm also having a similar problem with my plasma I get power but no picture or sound I turn unit on and get slightly a grey glow was recommended to replace YSUS and Y buffer boards but didn't help any. I've done the wire in EXT_AUTO_GEN and hole next to it and it goes thru the color cycle any ideas?
          • openminded
            can anyone help with enabling UMA on the 9500 XPS board ( LA-J191P ) ?
            by openminded
            in the mean time I wrote the second link to the chip, placed it and the laptop went on and showed the card.
            Just like before after a reboot the error 43 came up.
            I tried to heat the ram chips and the actual dGPU chiop without success - even with 2 RAM chips less it behaves the same.
            Giving up on making it work, can anyone help with enabling UMA on the 9500 XPS board ( LA-J191P )?
            I have never done this and been trying to understand it from the schematics, but for a beginner as I am it is hard to understand from that.
            Page 15 has some info mentioning UMA and...
            09-16-2024, 07:44 AM
          • Fripacks
            No picture LG model 50PT350
            by Fripacks
            Hi guys,
            I have problems no picture with LG model 50PT350, first of all, I change the 2 buffer boards who was no good, the TV working 2 weeks and today same problem, I check and I found Zsus board defect now, I change it for a new one and no picture, I check VS VA and 5 volts , all this voltage are there, I disconnect the upper buffer board, no picture, I disconnect the lower buffer board, no picture, what I have to check now?...
            05-19-2023, 12:06 PM
          • arif3203
            can anyone help with enabling UMA on the Lenovo E14 nm-c421
            by arif3203
            Hallo All,
            Please help for Dis to uma in lenovo E14 NM-C421 Problem Display Artefact test shift R0824 and remove coil not work.Thank you
            11-23-2024, 12:07 AM
          • uuu31
            Enabling WiFi on Dell Precision 7670
            by uuu31
            I've been trying to re-enable WiFi on this laptop that has a factory option to disable it "permanently" (WLAN option greyed out in bios). I've tried modding the bios myself (clearing service tag/ manufacturing mode) and editing the UEFI variables for default settings to see if I could change that, but that didn't work and I figured I'd ask for help. I'm not sure, but I think it may be disabled somehow by the EC. Any help would be appreciated.
            08-27-2024, 11:26 AM
          • TheKROCZ
            Need help with enabling dGPU support on Acer IPIMB-AR Rev 1.02A
            by TheKROCZ
            Hello everyone. As the title says, I need help with enabling dGPU support on my Acer motherboard. It has a pcie 3.0 x16 slot which I would like to use with a gtx 750ti I have laying around. However, upon booting it up with the dgpu, the bios tends to crash. It just freezes at the Acer splash screen and becomes unresponsive.
            Upon further research, I discovered that everyone with my motherboard faced this issue. Apparently, it was just not possible because the bios happened to be some hybrid of a uefi and legacy bios which led to dgpus having a tough time figuring out whether they...
            08-07-2022, 07:38 AM
