LG 50PT350 Help
  • Bobabrett
    • Apr 2014
    • 15
    LG 50PT350 Help
    Really stumped on this one. When TV is turned on I get cable for about 3 seconds and then the screen goes black but audio continues. When I change to a different video source like HDMI 2, EXT, etc the menu comes up and even the screen saver comes on. I just can't get any picture on cable or even if I hook up a gaming console, that won't come on.
    Took off the back, no blown capacitors or anything. I have a Multimeter at my office, just not at home, wanted to talk through the problem before I go looking for ohm readings.
    any ideas what it could be?
    Re: LG 50PT350 Help
    Have you tried enabling the EXT AUTO GEN on the control board? Pictures of the boards would help.
    • Bobabrett
      • Apr 2014
      • 15
      Re: LG 50PT350 Help
      Hi Tom,
      I have not tried enabling the EXT AUTO GEN on the control board. How do I do that and what will it do?
      Below are photos of the boards. Thank you in advance.
        Re: LG 50PT350 Help
        I require a closer shot of this board.
        http://paperthinmedia.com/download/e.../image(2).jpeg
        Then a small piece of wire can be used to turn on the auto pattern generator.
        • Bobabrett
          • Apr 2014
          • 15
          Re: LG 50PT350 Help
          Tom,
          I've attached a closer image of this board. Let me know if this will suffice
          Thank you.
            Re: LG 50PT350 Help
            OK, see the hole marked EXT_AUTO_GEN, and just to the right of it, under some tape, the other hole? Peel back the tape slightly, take a small piece of wire, and connect these points. Then remove the right hand cable going between the control and main boards. Turn the TV on and you should get cycling test patterns - do you?
            • Bobabrett
              • Apr 2014
              • 15
              Re: LG 50PT350 Help
              Tom,
              I followed your instructions and got a blank screen. The backlights looked like they were on but nothing came on the screen. To very I did this correctly I included a photo.
              Thanks!
                Re: LG 50PT350 Help
                It might be a good idea to try soldering the jumper in place quickly, it can be hard to make sure it is making connection.
                • Bobabrett
                  • Apr 2014
                  • 15
                  Re: LG 50PT350 Help
                  Tom,
                  finally had a chance and got a new piece of wire and soldered it in a bit. Got something new this time. When I turned it on, the TV screen went all blue and then shut itself off after a few seconds.
                    Re: LG 50PT350 Help
                    OK, that means we have to do one last thing, the main board appears to be turning off the TV. The connector between the main board and power board. Please remove this from the main board end and locate the pins AUTO_GND and GND. Connect these pins together with a wire. Then turn TV on, the patterns should cycle indefinitely, do they?
                    • Bobabrett
                      • Apr 2014
                      • 15
                      Re: LG 50PT350 Help
                      You might have lost me here.. do you have an example of this, or is there an easier way?
                      Thanks again Tom.
                        Re: LG 50PT350 Help
                        There should be a label next to the connector on the power board, is there?
                        SM http://servicemanuals.pro/serviceman.../download.html
                        • Bobabrett
                          • Apr 2014
                          • 15
                          Re: LG 50PT350 Help
                          Is this the one you speak of? If yes, how do I connect them?
                          Thanks again for your help.
                            Re: LG 50PT350 Help
                            Correction, you should just be able to leave that connector unplugged and TV will turn on automatically. then it should go through the test patterns. If it does not you have a control board or power board issue.
                            • Bobabrett
                              • Apr 2014
                              • 15
                              Re: LG 50PT350 Help
                              When the jumper cable is connected to the EXT_AUTO_GEN and to hole on the right of it and that cable is unplugged, I get a blue screen and it immediately shuts off. So, if that means I have a control board or power issue, is there a way I can tell which one? Would I be able to use my Multimeter on the power board to find the culprit or at least narrow it down?
                                Re: LG 50PT350 Help
                                Yes - can you use your multimeter to check the Vs and Va test points on the power supply - I think they are the wire links marked VS_TP and VA_TP.
                                Use DC volts, highest scale. Red probe on test point, black probe on the chassis.
                                They should be about 200V & 60V, exact rating printed on the plasma panel's model label (marked LG Electronics PDP50T1##### Made in <Country>... this is different from the TV's 50PT350 model number.)
                                • Bobabrett
                                  • Apr 2014
                                  • 15
                                  Re: LG 50PT350 Help
                                  OK--I know it's been months since I posted about this but I've been traveling and working on the TV as a side project. I replaced the logic board on the TV and I got excited--I turned it on and TV started playing---for about 5 minutes and then the screen went out again. I turned it off and turned it back on and I got a blank screen. I then turned the TV off for 1 minute, turned it back on and once again the TV worked for 5 minutes before the screen going blank (still audio from the station).
                                  Please help!
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Re: LG 50PT350 Help
                                    Sounds like you got a bad logic board. Try spraying a little cool air over it from a duster can and see if pic comes back on.
                                    And make sure all cables/ribbons are seated properly.
                                    • Bobabrett
                                      • Apr 2014
                                      • 15
                                      Re: LG 50PT350 Help
                                      I really don't think it's the logic board since I just replaced that part and it's basically doing what it was doing before. Other thoughts on what it could be?
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Re: LG 50PT350 Help
                                        Have you done what tom66 suggested in post #16 ? Take voltage readings when you have a pic and again when it goes out. Sounds like a voltage could be dropping out due to cold solder joint or component being flaky when heating up. I still recommend using a duster can to cool down components just not sure where lol. If you find a suspect voltage that will narrow down the location.
                                        • openminded
                                          can anyone help with enabling UMA on the 9500 XPS board ( LA-J191P ) ?
                                          by openminded
                                          in the mean time I wrote the second link to the chip, placed it and the laptop went on and showed the card.
                                          Just like before after a reboot the error 43 came up.
                                          I tried to heat the ram chips and the actual dGPU chiop without success - even with 2 RAM chips less it behaves the same.
                                          Giving up on making it work, can anyone help with enabling UMA on the 9500 XPS board ( LA-J191P )?
                                          I have never done this and been trying to understand it from the schematics, but for a beginner as I am it is hard to understand from that.
                                          Page 15 has some info mentioning UMA and...
                                          09-16-2024, 07:44 AM
                                        • Fripacks
                                          No picture LG model 50PT350
                                          by Fripacks
                                          Hi guys,
                                          I have problems no picture with LG model 50PT350, first of all, I change the 2 buffer boards who was no good, the TV working 2 weeks and today same problem, I check and I found Zsus board defect now, I change it for a new one and no picture, I check VS VA and 5 volts , all this voltage are there, I disconnect the upper buffer board, no picture, I disconnect the lower buffer board, no picture, what I have to check now?...
                                          05-19-2023, 12:06 PM
                                        • arif3203
                                          can anyone help with enabling UMA on the Lenovo E14 nm-c421
                                          by arif3203
                                          Hallo All,
                                          Please help for Dis to uma in lenovo E14 NM-C421 Problem Display Artefact test shift R0824 and remove coil not work.Thank you
                                          11-23-2024, 12:07 AM
                                        • uuu31
                                          Enabling WiFi on Dell Precision 7670
                                          by uuu31
                                          I've been trying to re-enable WiFi on this laptop that has a factory option to disable it "permanently" (WLAN option greyed out in bios). I've tried modding the bios myself (clearing service tag/ manufacturing mode) and editing the UEFI variables for default settings to see if I could change that, but that didn't work and I figured I'd ask for help. I'm not sure, but I think it may be disabled somehow by the EC. Any help would be appreciated.
                                          08-27-2024, 11:26 AM
                                        • TheKROCZ
                                          Need help with enabling dGPU support on Acer IPIMB-AR Rev 1.02A
                                          by TheKROCZ
                                          Hello everyone. As the title says, I need help with enabling dGPU support on my Acer motherboard. It has a pcie 3.0 x16 slot which I would like to use with a gtx 750ti I have laying around. However, upon booting it up with the dgpu, the bios tends to crash. It just freezes at the Acer splash screen and becomes unresponsive.
                                          Upon further research, I discovered that everyone with my motherboard faced this issue. Apparently, it was just not possible because the bios happened to be some hybrid of a uefi and legacy bios which led to dgpus having a tough time figuring out whether they...
                                          08-07-2022, 07:38 AM
