voltage reading on heat sinks
  • un4givintoo
    • Apr 2014
    • 14
    • usa
    may be a dumb question, but am supposed to have any voltage on my heat sinks or could that be a bad transistor?
  • mmartell
    • Oct 2013
    • 3189
    Re: voltage reading on heat sinks
    Depends on where they are. I think you're likely to find some in the primary that are hot.
    • un4givintoo
      • Apr 2014
      • 14
      • usa
      ive got continuity between my heat sink and one of my transistor legs, forgive my newbyness
        That's pretty normal, although I was repairing one power supply and I damaged the mica insulator while repairing it, the effect was that I had drain shorted to the heatsink and the heatsink was already tied to the source/ground, naturally this did make a nice fuse pop!
        • un4givintoo
          • Apr 2014
          • 14
          • usa
          thanks guys
          • japlytic
            • Oct 2005
            • 2086
            Have you seen the message "Test before touching" with regard to heatsinks being live?
            • un4givintoo
              • Apr 2014
              • 14
              • usa
              no ill check that out
              • mmartell
                • Oct 2013
                • 3189
                He means put a meter on it like you would anything else to test for voltage BEFORE you touch it with your hands.
                • abajor
                  A2141 PP3v3_G3H_RTC_X Diode Reading .104V Voltage 3.39V
                  by abajor
                  Have an A2141 which is reading about 5.2V 0.07A on all USB jacks, started doing the measurements.
                  PPBUS_3GH diode: measures good .45V
                  PPBUS_3GH Voltage: maybe not so good 12.25V maybe bad T2? Unit did not come up in DFU on configurator.
                  The weird so far is
                  PP3v3_G3H_RTC_X diode: .104V (WTF?)
                  PP3v3_G3H_RTC_X voltage: 3.39V (Normal)
                  Stopped there attempted reverse voltage injection at PP3v3_G3H_RTC_X with 1V. Instead of the circuit sinking any current, My PSU suddenly reads 3.4V with no current draw.
                  Not sure what any of this means...
                  03-18-2025, 10:27 PM
                • jm1234
                  Solder joints on heat sinks matter?
                  by jm1234
                  solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
                  I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
                  04-28-2024, 04:38 AM
                • alro7779
                  MOSFET? Is its voltage reading normal?
                  by alro7779
                  Hello, guys!
                  Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
                  06-19-2025, 08:19 AM
                • rddube
                  Lenovo L490 Ram voltage circuit malfunction
                  by rddube
                  Hello friends,
                  Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                  I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                  07-15-2025, 04:41 PM
